Topics [0]
bevel box and drive shaftby martindavid | 8 | 1977 | Wed Sep 07, 2011 10:28 pm by charlie99 |
You must have used hulk strengthby CommanderKewl | 2 | 1310 | Sat Sep 03, 2011 12:38 pm by CommanderKewl |
Fuel Tank Cleanby CanberraDave | 15 | 4731 | Sat Sep 03, 2011 12:13 pm by club_c |
Output Shaft Inspection[ 1, 2 ] by hot_seat | 79 | 5052 | Sat Sep 03, 2011 1:44 am by Rick G |
faulty k100 gearboxby gabriel | 2 | 1962 | Fri Sep 02, 2011 10:51 pm by Rick G |
My 75C is back on the road!by 8675k | 2 | 1299 | Fri Sep 02, 2011 8:46 pm by blaKey |
faulty speedo!!!!by gabriel | 1 | 1338 | Wed Aug 31, 2011 10:20 am by Rick G |
K1100 power plant g/box into k100by colesy | 6 | 2661 | Tue Aug 30, 2011 4:33 am by charlie99 |
The best way to remove a stripped oil filler screw?by Guest | 8 | 1869 | Sun Aug 28, 2011 6:35 am by charlie99 |
clunky clutch?by SittingDuck | 18 | 2314 | Sat Aug 27, 2011 9:23 pm by Rick G |
extra neutrals in gearbox...by twincarb | 21 | 1911 | Fri Aug 26, 2011 3:51 pm by walfish |
Gearbox oil levelby Reddragon52 | 8 | 5266 | Wed Aug 24, 2011 10:13 pm by blaKey |
Does anyone use of Rotella diesel oil in a K100by robmack | 13 | 3708 | Mon Aug 22, 2011 8:38 pm by robmack |
Will not go into first gear.by nick | 11 | 2056 | Mon Aug 22, 2011 12:21 pm by charlie99 |
output shaft 6 rivet to 12 rivet conversionby hot_seat | 5 | 1985 | Sat Aug 20, 2011 9:47 pm by charlie99 |
'84 driveshaft-diff housing transplant...by twincarb | 9 | 1877 | Thu Aug 18, 2011 8:12 pm by Avenger GT |
K100RT -85 run too rich.by towu | 3 | 1773 | Mon Aug 15, 2011 1:26 pm by japuentes |
Sould I be worried about the driveshaft?by SittingDuck | 24 | 2361 | Mon Aug 15, 2011 5:47 am by Guest |
Bevel Gear repairby twincarb | 8 | 3135 | Fri Aug 12, 2011 7:27 pm by twincarb |
Rear drive breather '85 K100by Lone Amigo | 7 | 1685 | Thu Aug 11, 2011 7:20 am by Inge K. |
Fuel tank part???by twincarb | 15 | 3980 | Mon Aug 08, 2011 8:50 pm by Rick G |
Oil filter cover o ringby hot_seat | 10 | 2169 | Mon Aug 08, 2011 6:09 am by Guest |
Changing the camchain- tensionerblade plastic faceby tjbergli | 2 | 1441 | Wed Aug 03, 2011 12:58 pm by tjbergli |
weird behavior at higher rpm K100LT `89[ 1, 2 ] by pajonk | 53 | 3102 | Mon Aug 01, 2011 3:41 pm by pajonk |
weird and scary noises coming from the gearbox/engine area...by pajonk | 4 | 2434 | Mon Aug 01, 2011 3:40 pm by pajonk |
Oil filter replacement??by Toto_jp | 23 | 2369 | Sun Jul 31, 2011 4:08 am by K-BIKE |
Exhaust shieldby twincarb | 5 | 1776 | Sat Jul 30, 2011 9:54 am by Inge K. |
Balancing throttle bodies[ 1, 2 ] by pjjms | 52 | 9534 | Thu Jul 28, 2011 7:27 am by Guest |
engine condition query?by colesy | 30 | 2561 | Wed Jul 27, 2011 5:30 am by charlie99 |
Replacing fuel hosesby chronostorm | 10 | 1999 | Tue Jul 19, 2011 10:22 am by RT |
EFI Moduleby 8675k | 6 | 1557 | Mon Jul 18, 2011 10:58 am by Rick G |
85 k100 choke vs. t.p.s.by whhoon | 4 | 1754 | Sat Jul 16, 2011 4:16 pm by K-BIKE |
K100RT Intermediate Gear Repair Threadby robmack | 34 | 4331 | Sat Jul 16, 2011 4:56 am by Guest |
output shaft rivetsby yankeeone | 6 | 1966 | Tue Jul 12, 2011 12:17 pm by Alex_GER |
need repairs in Montreal, suggestions for a decent shop or mechanic?by danielleforbeowulf | 1 | 1451 | Sat Jul 09, 2011 6:13 pm by K-BIKE |
oil/water pump rebuildby Crazy Frog | 1 | 4994 | Thu Jul 07, 2011 10:05 am by Gardell |
Throttle body butterfly shaft sealsby 8675k | 5 | 3609 | Thu Jun 30, 2011 4:02 am by K-BIKE |
Engine is missing / hesitating under load. Noticeable in 1,2,3 gears. Any ideas?by 1987k100rt | 14 | 6757 | Tue Jun 21, 2011 3:26 am by K-BIKE |
89 k100 Lt tachometer wont work and engine runs rough for no appearent reason. Changed plugs, checked relays, fuses, wires under tank. Need help.. Ran fine in January.by neffbmw | 15 | 2934 | Mon Jun 20, 2011 4:10 am by charlie99 |
Splines at gearbox end of drive shaft.by Avenger GT | 7 | 3425 | Sat Jun 11, 2011 11:12 pm by Avenger GT |
Trans knock?by chrish8846 | 16 | 2143 | Fri Jun 10, 2011 12:43 pm by chrish8846 |
clutch pack balance?by yankeeone | 3 | 1555 | Thu Jun 09, 2011 11:03 pm by yankeeone |
Performanceby chrish8846 | 25 | 3536 | Tue Jun 07, 2011 5:00 am by charlie99 |
Help k100 lt engine issuesby Gaxi | 5 | 2376 | Sat Jun 04, 2011 3:07 pm by ReneZ |
Flooding on throttle off = TPS?by wedge | 37 | 4311 | Thu Jun 02, 2011 2:30 am by K-BIKE |
FUEL PUMP REPLACEMENTby CanberraDave | 19 | 6892 | Mon May 30, 2011 7:41 am by BIG D |
Water pumpby chrish8846 | 2 | 1470 | Wed May 25, 2011 12:54 pm by chrish8846 |
Im back with the 86 75c with the rich running issueby 8675k | 3 | 1458 | Tue May 24, 2011 1:43 pm by club_c |
I have a high pitched whine in or near the clutch coverby liketobike | 3 | 1912 | Sun May 22, 2011 10:42 pm by Rick G |
sprag clutch 86 k100by yankeeone | 11 | 2790 | Sun May 22, 2011 5:49 pm by yankeeone |
Topics [50]
- No new posts
- New posts
- New posts [ Popular ]
- New posts [ Locked ]
