You can now order the forum stickers. Login and go to the "members only" forum. This is not available for guests yet....
1Back to top Go down    Misfire K100 on Sat 13 Jun 2015 - 1:11
wetdog
OK first post and its for help , I have a misfire ( really only running on 3 )  , I have changed , fuel pump , injectors , coils and leads plugs , ignition brain , I will look at comp next , the bike has done about 200,000 and never missed a beat so im in shock , anything else before I start to strip the motor , or replace which is more likely
2Back to top Go down    Re: Misfire K100 on Sat 13 Jun 2015 - 3:32
Welcome to the forum.
Probably a good idea to set a separate thread for the problem and pop in the bike model, year and VIN as there are differences that may affect what advice you get. That way you have all the information you need in one thread.
Misfire on one of the four, if its a specific cylinder, may have other causes. Coils are twin coils and can be swapped to rule them out. The motors are pretty unburstable and most of us only have to go as far as timing chains and valve clearances adjustments and also oil/water pumps so in short term I don't see stripping the engine as being needed until you have run some other checks. Never rule out the possibility of a new plug being faulty either.......been there on that one.
1992 K100LT 0193214 101,000 miles
1984 K100RT 0022575 Baja Red bought 36,000 now 89,150 miles
1997 K1100LT 0188024 58,645 now 64,500 miles
3Back to top Go down    Re: Misfire K100 on Sat 13 Jun 2015 - 4:06
with 200,000 on the clock ...likely to be throttle body rubbers
its just an age and rubber thing
worth inspecting anyhow
lots of threads about this issue throughout the forum
welcome aboard
4Back to top Go down    Re: Misfire K100 on Sat 13 Jun 2015 - 9:36
Welcome to the funny farm Wetdog. Check the valve clearances and for leaks in the inlet system below the throttle bodies.
If everything seems under control then you aint goin fast enough:- Mario Andretti
Bikes 1986 K100RT, 1993 K1100 LT, 1994 K1100 LT, 1993 K75 RT, 1996 K75RT, 1986 K75 GS, 1979 Z1300 Kawasaki X 2 & 1976 SR 500 Yamaha for now
5Back to top Go down    Re: Misfire K100 on Sat 13 Jun 2015 - 10:13
Hello Wetdog! I'm with Charlie and Rick on this one.
6Back to top Go down    Re: Misfire K100 on Sat 13 Jun 2015 - 16:34
wetdog
will swap the plugs again , you never know , im running the split fire plugs , have changed the coils off another k100 I have still the same , I may swap the flow meter over as I have one , I belive this started when water got into the fuel ( the tank drain was blocked and the bike lives out side 24/7 ) there is no water in the fuel system now
7Back to top Go down    Re: Misfire K100 on Sat 13 Jun 2015 - 17:42
@wetdog wrote:OK first post and its for help , I have a misfire ( really only running on 3 )  , I have changed , fuel pump , injectors , coils and leads plugs , ignition brain , I will look at comp next , the bike has done about 200,000 and never missed a beat so im in shock , anything else before I start to strip the motor , or replace which is more likely
What do you mean by "misfire (only running on 3)"?
Is it running rough or running sort of smooth on 3 cyl?
Which cyl is not firing properly?
What condition are the plugs? This can tell you which cyl is not running.
Does it idle when hot?
I'd have to agree with the above suggestions. Likely to be the TB rubber tho imo.
If one cyl is out...
  • It won't be ignition unless its a lead, cap or SP. have you got connectors screwed onto the SP tops? If you're going to swap plugs again use NKG.
  • It won't be fuel injection unless an injector plug is not connecting properly or you got a blocked injector. That could be a possibility if you got a leaky tank and water in the fuel. Injectors don't like water
That leaves induction. Leaky rubber or valve clearances.
1988 K100RT     VIN No.  0094680
     Fuel:  95 Octane
8Back to top Go down    Re: Misfire K100 on Sat 13 Jun 2015 - 18:00
wetdog
it some times drops onto 4 but will start and run fine (and ride) on 3 with the reduced power  , I have
NGKs coming , will look at the rubbers and VC , thanks for the ideas , the bike is not standard but has served me very very well for a £250 machine
9Back to top Go down    Re: Misfire K100 on Sun 14 Jun 2015 - 13:59
Mark K Boy
I have read the above...
If she is firing on 4 now and then:-
Maybe a plug lead - find the wet plug and try swapping out that lead.... ?
Mark Surman
Keep the shinny side up !
http://www.marksurman.com
10Back to top Go down    Re: Misfire K100 on Sun 28 Jun 2015 - 1:37
wetdog
crap after all that went back and cleared the fuel system again and found more water (I did not know water separated from fuel ) now running sweet as always , the drain from the filler
neck thro the tank for water to escape  was blocked , bike has lived out side for the last 10 years ,
