1Back to top Go down   K75 wont run properly Empty K75 wont run properly Sat Jun 13, 2015 5:46 am
werewasi
werewasi
K75 has up till now, run well but i stopped for lunch the other day, and about 1km after restarting, it started to run very roughly and wouldn't rev out, although ocassionally it would clear and rev hard.
I went back later in the day and picked it up and checked the fuel supply to the rail and that there was petrol going back into the tank. Conclusion - not a faulty fuel pressure regulator (and fuel tank very clean).
Started the bike up and it ran normally but 3kms down the road, it started dying again. Would only rev to about 2000 rpm and behaviour was not unlike that of the K100RS when the H E sensor failed in the heat. It's cool here at the moment so i don't think that is the problem. It's also not a tank vacuum problem.
It it Ok to assume that because, i have a fuel loop that the F P R cannot be the culprit?
I'm going to get a new set of injectors from the guy in Idaho but is there anything else worth checking in the meantime?
K100RS  1983 and 1986 (bought a 2nd and put them both together in a dark garage thinking that i would get a heap of parts from the progeny but nothing happened- think they're gay)  Laughing Laughing Laughing
1985 K75, Guzzi V7 Special, 1986 GB500, 1974 T500, 1986 MB5 with the whoppa 100cc engine transplant, NC 700 SA Honda, two 1986 Kawasaki BR250s
2Back to top Go down   K75 wont run properly Empty Re: K75 wont run properly Sat Jun 13, 2015 9:54 am
Fuel filter?  How long has it been in there?
Fuel pump?  They have been known to break.
3Back to top Go down   K75 wont run properly Empty Re: K75 wont run properly Sat Jun 13, 2015 7:17 pm
werewasi
werewasi
No, don't think that these are the culprits although I will inspect filters. Flow to rail was quite strong anf also back into tank so that seems to eliminate a pump problem
4Back to top Go down   K75 wont run properly Empty Re: K75 wont run properly Sat Jun 13, 2015 8:13 pm
Valve clearances OK??  Just a thought but the "on again, off again" behavior kind of points to electrical or elsewheres. Fuel pump connector being flakey maybe.
5Back to top Go down   K75 wont run properly Empty Re: K75 wont run properly Sat Jun 13, 2015 8:43 pm
Dave that is just about the right sort of time frame to get the Hall Sensors hot. I would be replacing them.
6Back to top Go down   K75 wont run properly Empty Re: K75 wont run properly Sat Jun 13, 2015 9:55 pm
Dave. I have a set of HES here for you. Rick's previous suggestion to bolt them on would be the quickest way to get you going for Tueusday.
But worth checking the valve clearances as its easy to do just to rule it in or out but not a quick fix if they're out. I have a few shims here but you'd be lucky if they're the right size.
 K75 wont run properly Austra12    Fuel:  95 Octane
7Back to top Go down   K75 wont run properly Empty Re: K75 wont run properly Sun Jun 14, 2015 6:34 am
werewasi
werewasi
thanks guys for the input.
i'll have to put this problem on the back burner because i'm flying out on tuesday morning to the Himalayan bike
ride and have to focus on making sure that i don't forget anything.
Have to ride an Enfield 500 whereas i'd prefer some little KTM hottie. At least it's fuel injected and needs to be to get over the Khardung La at 18500'. Probably a greater chance of my not coping with it.
8Back to top Go down   K75 wont run properly Empty Re: K75 wont run properly Sun Jun 14, 2015 6:53 am
Just do not leave deep ruts in the Kardung La - I want a fighting chance of getting up there after you!!
9Back to top Go down   K75 wont run properly Empty Re: K75 wont run properly Sun Jun 14, 2015 8:51 am
werewasi
werewasi
Just as they left a left a food dump for Scott, I will leave a cache of Evan Evans Warrior for you, at the top behind Maccas.
10Back to top Go down   K75 wont run properly Empty Re: K75 wont run properly Mon Jun 15, 2015 3:52 pm
Well, I had to look it up but as I'm in Brecon this August, I'll have to give some Warrior a try.
11Back to top Go down   K75 wont run properly Empty Re: K75 wont run properly Thu Jun 18, 2015 12:50 pm
werewasi
werewasi
I am in Delhi at the moment, Dai, and the traffic is just scary crazy. Don't seem to be any road rules and I have given up any idea of renting a bike to get around. Went out to see my bike hire guy and the Enfield 500 today and am sure that I wont be doing any mono wheeling on that beastie.
I don't know if you have been to India before but if not, you are in for a BIG new experience. Anyway, if you buy my book "Confessions of a Khardung La pussy" you will get plenty of insights into how to plan a Ladakh trip.
12Back to top Go down   K75 wont run properly Empty Re: K75 wont run properly Thu Jun 18, 2015 1:27 pm
well have to sort it when you get back mate
have a great trip
13Back to top Go down   K75 wont run properly Empty Re: K75 wont run properly Thu Jun 18, 2015 2:43 pm
Delhi... yeah. Been watching some fairly recent documentaries on Indian Railways; part of one was based in Delhi. That traffic would scare the kangaroo poo out of you, no trouble.
14Back to top Go down   K75 wont run properly Empty Re: K75 wont run properly Thu Jun 18, 2015 8:17 pm
I see it hasn't changed much from 1996, probably from chaos to chaos+ but it would be hard to be any worse.
I found it very overwhelming and just wanted to get the hell out of the place.
