1Back to top Go down   Starter PushButton Empty Starter PushButton on Wed Jun 17, 2015 5:00 pm
emmanuelfiadjoe
emmanuelfiadjoe
Where can I order online the starter PushButton for my K100RS 8V. The old one is broken.
Model: K 100 RS 83 (0502,0503,0513)
Series: K589 (k100, RS, RT, LT)
Production Month/Year: 07/1984
Region: Europe
VIN: 0018945
2Back to top Go down   Starter PushButton Empty Re: Starter PushButton on Wed Jun 17, 2015 6:45 pm
I'll stick my neck out and say that you cannot buy just the button, unless you buy a new right side switchblock assembly and wiring.
Or you can buy a second hand switchblock just to get a starter button. You run the risk of not knowing how fragile the second hand button is.
Search the Forum as this has been discussed previously.
Good luck.
If you come a cross a hoard of them, tell us!
Last edited by blaKey on Wed Jun 17, 2015 6:48 pm; edited 1 time in total (Reason for editing : I don't know, I was really drunk at the time!)
3Back to top Go down   Starter PushButton Empty Re: Starter PushButton on Wed Jun 17, 2015 7:26 pm
@emmanuelfiadjoe wrote:Where can I order online the starter PushButton for my K100RS 8V. The old one is broken.
Part number 61 31 1 459 462 (US$132.92*) will get you the right hand side combi assembly with headlight switch for K100RS. The green button and the red lever are not available separately.
*584.183 Cedi
1977 R75/7-R100 grey, '87 K100RS red, '93 K11-K12 aka 'Big Block' black, '96 K1100RS black, '98 K1200RS red, '09 K1300GT red, & 2013 R1200RT-Polizia black & white.
4Back to top Go down   Starter PushButton Empty This is just too much on Wed Jun 17, 2015 7:43 pm
emmanuelfiadjoe
emmanuelfiadjoe
That's about all my salary (GHC 667)  as a senior high school physics teacher. Smile
BTW, I did a little modification by passing a screw from the top of the cap into the little metal that makes contact with the leads. The pushbutton protrudes more, but it works just fine. My only concern is longevity. I hope I get a new one from an abandoned K here before the modification gives up.
Thanks all for your reply.
Region: Europe
VIN: 0018945
5Back to top Go down   Starter PushButton Empty Re: Starter PushButton on Wed Jun 17, 2015 8:21 pm
I had a similar thing happen to me about 10 years ago. A screw went in and then I covered the top of the screw with a plastic cap....or you could use the black plugger part in a syringe or needle. The bike is still in use except I have a different colour cap. In Australia certain plastics do not last long...especially the starter button.
6Back to top Go down   Starter PushButton Empty Re: Starter PushButton on Wed Jun 17, 2015 9:59 pm
Mine in OZ karked it soon after purchase. I glued it back together with 3M weatherstrip cement until the entire assembly died a death a few years later. Necessity is and always will be the mother of invention.
7Back to top Go down   Starter PushButton Empty Re: Starter PushButton on Wed Jun 17, 2015 11:29 pm
I think the major concern is that water can get into the switch block and cause other problems.
I stuck a plunger rubber from a 5ml syringe over mine. Been there for nearly a year now no probs.
  Starter PushButton Austra12    Fuel:  95 Octane
8Back to top Go down   Starter PushButton Empty Re: Starter PushButton on Thu Jun 18, 2015 12:12 am
There is a member in Spain who used a 3D printer to make some but I haven't seen him around for ages. If I could remember his name I would PM him.
9Back to top Go down   Starter PushButton Empty Re: Starter PushButton on Thu Jun 18, 2015 12:21 am
brickrider
brickrider
Makes all us ol' Luddites long for the return of proper kick start levers.  Razz
10Back to top Go down   Starter PushButton Empty Re: Starter PushButton on Thu Jun 18, 2015 2:51 am
@brickrider wrote:Makes all us ol' Luddites long for the return of proper kick start levers.  Razz
It makes it a simple process but unfortunately some of the big twins and singles had a habit of launching you over the handlebars. Laughing
11Back to top Go down   Starter PushButton Empty Re: Starter PushButton on Thu Jun 18, 2015 3:09 am
BadjerJim
BadjerJim
Had the same problem, and was lucky enough to find a guy parting-out a bike, and sold me the right-hand switches for $20.  And yeah, the only part that I used was that little green button.  Of course now I have an extra red kill switch lever, and some wiring that I'll keep but never use.
The green starter button would be an ideal candidate for 3D Printing.  Now that I think of it, it would be great to set up an archive area of this forum for 3D Printing files... for this and other small plastic parts.
12Back to top Go down   Starter PushButton Empty Re: Starter PushButton on Thu Jun 18, 2015 3:59 am
emmanuelfiadjoe
emmanuelfiadjoe
Then I'll get some rubber to cover mine.
Thank you all
Region: Europe
VIN: 0018945
13Back to top Go down   Starter PushButton Empty Re: Starter PushButton on Thu Jun 18, 2015 4:23 am
@BadjerJim wrote:Had the same problem, and was lucky enough to find a guy parting-out a bike, and sold me the right-hand switches for $20.  And yeah, the only part that I used was that little green button.  Of course now I have an extra red kill switch lever, and some wiring that I'll keep but never use.
our workplace has one of those new printers ...might be a good idea to take a scan of one before it breaks
hmmm
good idea jim ...thanks for the reminder
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%OStarter PushButton Au-log10
14Back to top Go down   Starter PushButton Empty Re: Starter PushButton on Fri Jun 19, 2015 12:08 am
Work also has a new printer.
They want to test their modelling and printing skills.
I was told to bring in a button and the speedo gears for modelling and manufacture.
Will keep you posted.
15Back to top Go down   Starter PushButton Empty Re: Starter PushButton on Fri Jun 19, 2015 12:23 am
That could make you a very popular person.
16Back to top Go down   Starter PushButton Empty Re: Starter PushButton on Fri Jun 19, 2015 12:49 am
rawdonball
rawdonball
The '85 K100RS I purchased 12 months back had a nice IP65 rated push button switch assembly installed in the bore normally used for mounting the rear view mirror on naked and K75C models. Easy job to reroute the wires, switch is not inaccessible and water proof as all hell.
17Back to top Go down   Starter PushButton Empty Re: Starter PushButton on Fri Jun 19, 2015 1:23 am
I had that in place of an indicator switch on the K100 for a few years.
18Back to top Go down   Starter PushButton Empty Re: Starter PushButton on Fri Jun 19, 2015 2:32 am
crikey if you can get the scan / cad  file rossko (3d modelling )  save as ?.stl
we should be able to convert it anyhow to our standard at least
ill give it a go up here on ours as well
good onya
19Back to top Go down   Starter PushButton Empty Re: Starter PushButton on Sat Jun 20, 2015 5:07 am
I will post pictures later, but had to do some major butchery on my starter switch to get the green button out without damaging it any more.
Might have to get one of them made also.
20Back to top Go down   Starter PushButton Empty Re: Starter PushButton on Sat Jun 20, 2015 8:31 am
With the remnants of the green button so difficult to get out without further damage, how will the new button be installed? This could be a problem Shocked
21Back to top Go down   Starter PushButton Empty Re: Starter PushButton on Sat Jun 20, 2015 10:07 pm
looks like the brass section of the contact at the inards side is glued - heated into place ...possibly on a pike into the green button
the emergency cutoff button and green button are easily removed as an assembly but hard to separate up the core of the cutoff switch inards
maybe a cutoff wheel on a dremel could cut the outer part in half to expose the push button
ill give It ago later, if there is interest
22Back to top Go down   Starter PushButton Empty Re: Starter PushButton on Sat Jun 20, 2015 11:01 pm
Don't destroy yours Charlie. Already done it to miine.
Pics will follow when I can get a camera to focus close enough to see what is going on
23Back to top Go down   Starter PushButton Empty Re: Starter PushButton on Wed Jun 24, 2015 4:52 pm
I had a look at an assembly today, and I'd like to know how the contact is secured into the green button. Moulded, glued or something else?
Got any pics yet rosskko?
I'm thinking it may be possible to put a thread in the button and make the contact with a brass round head screw??
(It would be nice to have a blue button on the blue bike.)
24Back to top Go down   Starter PushButton Empty Re: Starter PushButton on Wed Jun 24, 2015 5:08 pm
Paul, the peg is held in by friction.
It has a little knurled section on the end.
Impossible to get out unless you destroy the red switch.
I was thinking the same thing with the screw. Only thing is, if you ever have to replace the button, you probably won't have to pull it out again for another twenty years.
I have the button and switch with a design guy at work to make a model, he is talking about making a mould to make them out of more durable plastic.
Will probably do both to make a new set.
I suppose the button post could be removed by drilling it out to weaken the hold on the metal pin.
The other thing I was thinking is the spring could be cut down by 1/3. It is very strong for its role and probably has a hand in popping the top off the button
25Back to top Go down   Starter PushButton Empty Re: Starter PushButton on Wed Jun 24, 2015 5:24 pm
Thanks, rosskko.   Starter PushButton 112350
P
26Back to top Go down   Starter PushButton Empty Re: Starter PushButton on Wed Jun 24, 2015 9:38 pm
We all wish you luck in this little adventure!
27Back to top Go down   Starter PushButton Empty Re: Starter PushButton on Wed Jun 24, 2015 10:48 pm
good work rossko
yes your right Paul a 2mm bolt should work just fine   and may have the same head contact interference to the switch ?
28Back to top Go down   Starter PushButton Empty Re: Starter PushButton on Tue Jul 07, 2015 7:11 pm
Well, I couldn't resist it, using rosskko's info, I decided to drill out the contact pin on a spare switch block. As the shaft is 2.5 mm diameter it was easy enough and the red lever stayed intact.  cheers
Starter PushButton Sam_1211
I then turned a replacement push button in brass with a 6BA thread to use a cheese head screw with it's head turned to 3.5 mm as the contact.
Etch primed and painted blue, now there's no green bits on my blue bike.  Starter PushButton 723598Starter PushButton Sam_1212
Charlie, do you think this colour matching is getting out of hand???
29Back to top Go down   Starter PushButton Empty Re: Starter PushButton on Tue Jul 07, 2015 8:55 pm
Good work SCP.
Wish I had know how they went together before destroying mine.
Still waiting on the techie to model the button.
Despite their initial excitement they are a bit slow.
30Back to top Go down   Starter PushButton Empty Re: Starter PushButton on Tue Jul 07, 2015 9:09 pm
Love it Paul, absolutely love it!
Taking the concept of a unique bike to a whole new level.
31Back to top Go down   Starter PushButton Empty Re: Starter PushButton on Tue Jul 07, 2015 9:35 pm
pretty good result paul
yes I think your right ...some of us have gone over the edge with the colour matching ...perhaps ...but I understand the need mate .
32Back to top Go down   Starter PushButton Empty Re: Starter PushButton on Thu Jul 09, 2015 9:11 pm
Excellent work there Paul.
Do you take orders? No...seriously, do you? A nice little bunsen burner for you there!
I get excited if I don't cross thread the valve cap when checking the air in my tyres, so there's no way in the world that I'll ever be able to do what you did.
33Back to top Go down   Starter PushButton Empty Re: Starter PushButton on Fri Jul 10, 2015 4:29 am
Starter PushButton 44271
good one blakey ..
and he with 3 of the things ....
I must get up there again soon
34Back to top Go down   Starter PushButton Empty Re: Starter PushButton on Sun Jul 12, 2015 5:39 pm
@emmanuelfiadjoe wrote:That's about all my salary (GHC 667) as a senior high school physics teacher. Smile
Thanks all for your replies.
I suppose those of us in 'the West' need a dose of reality once in a while as to how lucky we really are, in relative terms, with options and access to parts merely a phone call or quick Google search away, and often as cheap as chips.
35Back to top Go down   Starter PushButton Empty Re: Starter PushButton on Tue Jul 14, 2015 5:44 pm
Sage words, TWB, in countries with a proliferation of K's we're spoilt by having an easy supply of new and used spares.  roundel
I wonder how many new K's were delivered to Ghana?
Anyway, emmanualfiadjoe, if you PM me your address I'll send you a replacement starter button.
36Back to top Go down   Starter PushButton Empty Re: Starter PushButton on Wed Jul 15, 2015 12:08 am
Nice work SCP. Make sure to get the colour correct.
37Back to top Go down   Starter PushButton Empty Re: Starter PushButton on Wed Jul 15, 2015 5:10 am
wow  ...amazing paul
good on you !!
38Back to top Go down   Starter PushButton Empty Re: Starter PushButton on Wed Jul 15, 2015 7:30 pm
Good work Paul.
39Back to top Go down   Starter PushButton Empty Re: Starter PushButton on Thu Jul 16, 2015 4:49 am
Great to see so many contributing and helping fellow Knuts.
