marknico
marknico
Hi all took the abs system off my bike and have the abs brain plus 2 modulators free if anybody wants them but must be collected from sy13 4eh - bike is a 16v k100 rs 1990 model - I`m also after a rear brake calliper for bike doesn't have to be the abs one now ( brembo 2 pot type ) cheers
FYI, the calipers are the same whether ABS or not, K75, K100, K1100. Just unscrew the ABS sensor bracket from the caliper and there you go. Even a K1200LT/RS/GT will fit the back end of an early K (however, some of the square Brembo pads are different part numbers as they're slightly dimensionally different so you must have the corresponding, correct brake pad size).
I'm practicing social media distancing; no Facecrack, Wazzup or Instagreedy!
1970 R60/5, '77 R75/7-R100, '85 K100'87 K75C, '87 K100RS, '93 K11-K12 Big Block, '93 K1100RS, '95 R100-Mystic, '96 K1100RS, '98 K1200RS, '00 K1200RS, '02 K1200RS, '03 K1200GT, '04 R1150R'04 R1150RT, '05 K1200S, '06 K1200R, '07 K1200R, '09 K1300GT & 2013 R1200RT-Polizia  - the Beemers in my life I can recall, owned still or sold on, since 1976.
marknico
marknico
@Two Wheels Better wrote:FYI, the calipers are the same whether ABS or not, K75, K100, K1100. Just unscrew the ABS sensor bracket from the caliper and there you go. Even a K1200LT/RS/GT will fit the back end of an early K (however, some of the square Brembo pads are different part numbers as they're slightly dimensionally different so you must have the corresponding, correct brake pad size).
Many thanks for info :0)
Correction, K1200LT (only) use a diferent rear caliper. Steer clear.
