You can now order the forum stickers. Login and go to the "members only" forum. This is not available for guests yet....
1Back to top Go down    What's this?? on Mon Jul 20, 2015 2:03 pm
I'm not even sure if its off the K but found it on the garage floor under the bike this evening after I'd just r&r the fairing. Could've been there before that tho.
Looks to me like its part of a switch but all the switches are working ok.
1988 K100RT VIN No. 0094680
1989 K100RT VIN No. 0097367 (naked)
1996 K1100RS VIN No. 0451808
Fuel: 95 Octane
Engine Oil:Nulon Full Synthetic 15W50
Gear Box Oil: Nulon Synthetic 75W90
2Back to top Go down    Re: What's this?? on Mon Jul 20, 2015 2:12 pm
Basic2
Clip for the fuel tank, flattened out. Don't ask why I know....
K100 Basic 2
11/1987 6308319K100CJ
Marakesh Red
3Back to top Go down    Re: What's this?? on Mon Jul 20, 2015 2:29 pm
The clip for the fuel tank looks a bit different...............
No idea about the first clip, tho.
4Back to top Go down    Re: What's this?? on Mon Jul 20, 2015 2:40 pm
Thanks Basic2. If you're refering to the two mounting lugs at the rear of the tank, its way too small. Never had tank clips anyway.
Fuel: 95 Octane
5Back to top Go down    Re: What's this?? on Mon Jul 20, 2015 2:46 pm
Just so we don't get side tracked, I don't think its a clip. The prongs are parrallel.
Fuel: 95 Octane
6Back to top Go down    Re: What's this?? on Mon Jul 20, 2015 3:35 pm
That resembles a BMW lock cylinder 'tumbler' of the single sided variety.
'77 R75/7-1000cc, '87 K100RS, '93 w/K12 Big Block, '94 R100 Mystic, '03 K1200GT, '04 R1150RT, '06 K1200R, '07 K1200R & '09 K1300GT
7Back to top Go down    Re: What's this?? on Mon Jul 20, 2015 3:57 pm
Ahhh! Thanks TWB.
Had a couple of the pannier locks out last week. I remember one fell on the floor. Rolling Eyes
Just got to figure out how to reinstate that now.
Cheers mate Very Happy
Fuel: 95 Octane
8Back to top Go down    Re: What's this?? on Mon Jul 20, 2015 5:23 pm
One missing and the lock still works smoothly with your key? No worries, that only means one more in ten thousand can open your pannier with their key!
9Back to top Go down    Re: What's this?? on Mon Jul 20, 2015 7:21 pm
Snod Blatter
I've had one of these sat on my desk ever since I bought my K, it just fell out of one of the pannier latches. Can they be put back? The locks all work, one latch is a bit dodgy and I always blamed it on this little bit being missing but apparently it's not part of the opening/closing action?
1989 K100RS SE ABS 8v VIN: 0149214
Others: 1.5 x Honda CBX250RS-E, '94 CB250, '95 TRX850, '16 Z250SL
10Back to top Go down    Re: What's this?? on Mon Jul 20, 2015 7:50 pm
These pieces are the bits that stick out of the inside of the lock cylinder when the key is removed, causing the lock to stay in the holes it's supposed to be in, and keeping it locked. There are tiny springs next to each one which push the 'tumbler' out when the key is taken out. There are four different lengths of them and they relate to the depth of the cut in your key's shank - sticking up at equal heights when the key is in. If there is a tumbler or two missing the key will likely still work, be able to lock, but you increase the chance that someone else's key will fit your lock. In some dealerships the tech will simply grind off the high points of each tumbler except for the last one, which keeps the lock cylinder in your pannier, etc., but which, again, increases the chances another's key will fit.
Here's an example:
11Back to top Go down    Re: What's this?? on Mon Jul 20, 2015 7:59 pm
Snod Blatter
I see, thank you. So I should look into the dodgy latch a bit more..
