1 Weird Electrical Problem (Now Working) Tue Jul 21, 2015 10:00 am
TheJoker
Hi all, I've not long go back from my weeks holiday (unfortunatly never made it to york this time). Did do 1600 miles since last Saturday which included a day trip to France and Belgium on Sunday (came back this morning).
Anyway.
I've been having a few problems whilst I’ve been out riding first off I had the bike refusing to start. You press the starter and all you get is a zzt. However if I move a bit forward normally in gear with the clutch in the bike starts straight away. Whilst It's not starting I don't get any dimming, headlights turn on and work fine.
Second problem.
I was riding from Lille to Dunkirk Sunday night and over 3k revs, the headlight would dim; going to about 6k it's almost completely off. Under 3k the headlight works fine. To go with this I also have an indicator problem basically over 3k again I get sporadic hazard flashing when I press left or right. Or it only flashes once, sometimes they work like normal.
Now I've checked the battery earth and that is fine, the battery is also running at 12 volts. All bulbs are fine, they have been replaced with fresh.
Now I've heard these problems can do with the starter brushes any one think this sounds like the culprit ( The bike is my main form of transport so don't really want to take it apart if it might be something else I've overlooked.)
Anyway.
Second problem.
My Bike List past to present so far;
Lexmoto (first bike ever to ride) , CB125 TDC 86 , CG125 89 , GN125 97 , ER5 96 , K100 RS 84
84/01 K100rs 0013627
