Does anyone have a tip for stopping a leak from the wire to the oil pressure switch? It was weeping but has escalated into a drip and I don't want to go stripping the pump before the Irish eccentrics meet on the 8th.   Mad
oil pressure sensor switch wire....oil leak Ir-log1188....May contain nuts!oil pressure sensor switch wire....oil leak Ir-log11
K75RTP - 1994
my oil pressure switch started leaking will ...after the seals replacement job ...sounds just like your issue atm
ill guess it was the ultrasonic cleaning on the old epoxy  or got bumped during tightening ?
look around for a replacement is my guess
good luck
jbweld could probably solve the issue , with an extra layer over the epoxy ...but you might need a bung in there whilst taking it out
