1Back to top Go down   Vacuum tube caps Empty Vacuum tube caps on Wed Aug 19, 2015 4:27 pm
Some time ago, I think it was Kaptain Holister, suggested using generic vacuum tube caps rather than the BMW originals.
That prompted me to search e-bay for 4mm vacuum caps and I found these from China.
http://www.ebay.co.uk/itm/151669877430?_trksid=p2060353.m2749.l2648&ssPageName=STRK%3AMEBIDX%3AIT
Being longer and parallel, they are much easier to get on and off the vacuum take off points on the throttle bodies than the original short rounded ones, particularly No 1 cylinder with a fairing fitted.
I recently found 2 originals that I had dropped at some time, lurking under the air filter casing.  Embarassed
Vacuum tube caps Sam_1219
Being silicon rubber, they should be less prone to splitting with age than the BMW ones.
2Back to top Go down   Vacuum tube caps Empty Re: Vacuum tube caps on Wed Aug 19, 2015 6:08 pm
brickrider
brickrider
Excellent!  Thanks for that.  Those little OEM caps have always been a PITA.
Brickrider
1985 K100RS; brick red, of course!
3Back to top Go down   Vacuum tube caps Empty Re: Vacuum tube caps on Fri Aug 21, 2015 6:35 pm
WoodyAUK75
WoodyAUK75
Yep, I've ordered mine. The originals look like they may have a split up the side, but feel like they will fall apart if I try to take them off to examine them.
4Back to top Go down   Vacuum tube caps Empty Re: Vacuum tube caps on Fri Aug 21, 2015 11:29 pm
My oems were cracked and split also.
The ones I bought off the shelf at my local SuperCheap Auto store turned out to be vinyl but they're doing the job ok. AU$7 for a box of 6
Vacuum tube caps Vacuum10
  Vacuum tube caps Austra12    Fuel:  95 Octane
5Back to top Go down   Vacuum tube caps Empty Re: Vacuum tube caps on Sat Aug 22, 2015 5:40 am
I thought the tops off the plastic coated coat hangers would do the job ok
But not the white ones.
6Back to top Go down   Vacuum tube caps Empty Re: Vacuum tube caps on Mon Aug 24, 2015 3:36 pm
WHITE ones!......where can I get some.  Vacuum tube caps 652573
7Back to top Go down   Vacuum tube caps Empty Re: Vacuum tube caps on Mon Aug 24, 2015 6:22 pm
Vacuum tube caps Yellow10
8Back to top Go down   Vacuum tube caps Empty Re: Vacuum tube caps on Mon Aug 24, 2015 7:04 pm
lol!
'83 K100 upgraded to K100RS spec, '87 K100RT
'78 Moto Guzzi 850-T3, '79 Moto Guzzi 850-T3 California,'93 Moto Guzzi 1100ie California
