1Back to top Go down    K100 fuel tank on Wed Aug 19, 2015 5:31 pm
jdeath
Hi,
Does anyone know if the k1100 fuel tank will fit the k100?. Mine is leaking in the usual place, and wondered what my options are.
John
2Back to top Go down    Re: K100 fuel tank on Wed Aug 19, 2015 6:25 pm
I know for certain it wont fit early K100 with the bolted down tank as the connections etc are different.
Not sure about later8 valve K100or 16 valve K100s.
1992 K100LT 0193214 Alaska Blue 101,000 miles
1984 K100RT 0022575 Baja Red bought 36,000 now 89,150 miles
1997 K1100LT 0188024 Mystic Red 58,645 now 67,600 miles
3Back to top Go down    Re: K100 fuel tank on Wed Aug 19, 2015 7:22 pm
I see from your profile yours is an '87. I'm not sure when the change from the bolted tank took place but i think yours is the later type which should be interchangeable. The tank repair is not difficult, why change it? Use the search tab on the portal page to search and there are many expales of repairs and suitable materials.
88....May contain nuts!
4Back to top Go down    Re: K100 fuel tank on Wed Aug 19, 2015 8:46 pm
Yes they are the same tank.
"Every normal man must be tempted, at times, to spit upon his hands, hoist the black flag, and begin slitting throats." from Mencken's 1919 Prejudices
Bikes 1993 K1100 LT, 1998 K1100 LT, 1993 K75 RT, 1996 K75RT, 1986 K75 GS, 1979 Z1300 Kawasaki X 2 & 1976 SR 500 Yamaha for now
5Back to top Go down    Re: K100 fuel tank on Wed Aug 19, 2015 11:19 pm
If you have a good aluminium welder around...they can be welded....mine has been welded.
1983 K100basic vin 0003960 colour red
1987 K100RT vin 0094685 colour, orange peel, sorry, pearl
6Back to top Go down    Re: K100 fuel tank on Wed Aug 19, 2015 11:48 pm
Agree with Ainsjac, I'm another who went down the route of having the tank leak repaired by aluminium welding rather than an epoxy fix. I felt it was more permanent if you can find someone to do it.
95 K1100LT 0232224; 90 K75 6427509; 87 R80G/S PD 6292136
7Back to top Go down    Re: K100 fuel tank on Thu Aug 20, 2015 2:56 am
jdeath
Thanks for the replies,
I've already repaired it once with tank puttyand its leaked again (about a year later) I'll investigate and see if its from the same place or somewhere new. I'll also check the posts on repair you mention.
Thanks again
John
john k100 lt
8Back to top Go down    K100 fuel tank fix on Thu Aug 20, 2015 6:41 am
jimmy62alan
If anyone is stuck for alloy welding you can go to your local college and ask the welding instructor if they would let their experienced welders do the work for you, most instructors allow this as its goes towards the trainee's grades. I have done this when I have had no welder and have had bike frames fixed and all kinds. Could be worth a thought. you could take the welders name for future work as well.
ALAN
Sheffield S25
9Back to top Go down    fuel tank on Wed Sep 02, 2015 11:32 am
jdeath
thanks all,
ive sourced a k1100 tank,which fits,but on close inspection it also has 3 small pin holes.the seller did say that if any holes were present he could get it repaired at his place of work.so i will probably do that.bit o a hassle to drive back there to drop off and pick up but its in better condition than my original tank (rot wise).quite fancy the idea of polishing it up and leaving it in its natural alloy state so welding would look better than sticking a blob of filler on it i suppose
Last edited by jdeath on Wed Sep 02, 2015 12:11 pm; edited 1 time in total (Reason for editing : added more text)
john k100 lt
10Back to top Go down    Re: K100 fuel tank on Wed Sep 02, 2015 12:16 pm
Motorbike Mike
I'm that fed up with tanks leaking I've bought a welding set,Argon bottle and taught myself to ally weld.
It comes in handy.
I'd be disappointed if a K tank didn't leak!!
