You can now order the forum stickers. Login and go to the "members only" forum. This is not available for guests yet....
1Back to top Go down    Vibration Reduction on Mon Aug 31, 2015 5:40 pm
Be made
After many months of procrastination I have finally got around to resetting the engine/gearbox - frame bolts to the correct torque settings and tightening them in the correct sequence.
I also replaced the Cam chain guides and the Cam chain. I had a brand new one from the recond of the other engine (which only survived 3000k's due to another wrenches #$@%up) so, after giving it a lot of thought and consideration I thought to myself that maybe these things was responsible for at least some of the vibes. And I was right.
I have experienced about a 50% reduction in vibes and now it is at least bearable. I no longer get a numb hand until at least the first 45 minutes has passed as opposed to previously 15 - 20 minutes and when the hand does go numb it is restored a lot quicker - within a minute or so as opposed to about 2 - 3 minutes previously. I really enjoyed doing the job and had a great sense of satisfaction when we rode out for the first time when it was finished. According to Mr Haynes I had to remove both left and right engine covers to get the front one resealing properly but it was all good. The old guides showed a little bit of wear on the top one so I assume that was part of the source of vibration.
With my old engine, when I pulled it down to rebuild @ 110,000 k's, one of the guides was nearly sheared through and it looks like I just reached it in time. I am glad I have done this, I have great piece of mind knowing it has been done and will be good for another 60 - 100k.
My engine now has 66666ks on it.
P.s - I have an appointment at the hospital plastics unit for the carpel tunnell assessment on 18 sept :-)
2Back to top Go down    Re: Vibration Reduction on Mon Aug 31, 2015 6:06 pm
Brad-Man
Wonderful that you forestalled a disaster and reduced vibration at the same time!
Have you sync'd your TB's?
Brad
3Back to top Go down    Re: Vibration Reduction on Mon Aug 31, 2015 7:46 pm
Be made
@Brad-Man wrote:Have you sync'd your TB's?
Brad
Yep. Everything else is perfect at the mo bro.
Thanks for the post
4Back to top Go down    Re: Vibration Reduction on Mon Aug 31, 2015 8:23 pm
Can't tell from your images. How are your handlebar end weights? My K100 came without any, and a cheap set from eBay (marked with the triple tuning forks logo if you look closely) made quite a difference.
I'll be making a new heavier set on the lathe when I get a chance to see how more weight goes.
The lead shot in the handlebars idea may have merit, but my lead shot was too fine and fell through the handlebar holes in the middle. Maybe buckshot.
1985 K100RT VIN 0028991 My original Very Happy (Historic rego)
1985 K100RT VIN 0029036 BOB the Blue Old Bike (Historic rego)
1990 K100LT VIN 0190452 Work in progress
1984 K100RT VIN 0023022 Work needing lots of progress
1986 K100RT VIN 0090542 Work needing lots and lots of progress
1993 K1100LT VIN 0183046 Work in progress
1993 K75S VIN 0213045 Newest toy, slightly non-original
5Back to top Go down    Re: Vibration Reduction on Mon Aug 31, 2015 8:53 pm
Be made
@indian036 wrote:Can't tell from your images. How are your handlebar end weights? My K100 came without any, and a cheap set from eBay (marked with the triple tuning forks logo if you look closely) made quite a difference.
Yeah . . I had 330gm when purchased the bike as a standard LT and stupidly lost one. The heaviest I can get now is 170gm. Will add them at some point
6Back to top Go down    Re: Vibration Reduction on Fri Sep 11, 2015 1:03 am
Be made
@Be made wrote:Yeah . . I had 330gm when purchased the bike as a standard LT and stupidly lost one. The heaviest I can get now is 170gm. Will add them at some point
Bar weights added today. Same as the last lot. 330gm. A lot better but still wanting to improve
7Back to top Go down    Re: Vibration Reduction on Fri Sep 11, 2015 6:19 am
What speed is the worst vibration? I'm curious because my RS is a magic carpet up to about 60mph, at which point I get a high-frequency vibration. It's useful for not having to look down at the speedo but otherwise, damn annoying. At around 75mph it smooths out again.
8Back to top Go down    Re: Vibration Reduction on Fri Sep 11, 2015 6:44 am
The dreaded 4,000rpm vibration. Funny thing is my vibes on the RT disappeared.
1992 K100LT 0193214 101,000 miles
1984 K100RT 0022575 Baja Red bought 36,000 now 89,150 miles
1997 K1100LT 0188024 58,645 now 65,500miles
9Back to top Go down    Re: Vibration Reduction on Fri Sep 11, 2015 11:31 am
Have the balance of the front wheel checked.
1994 K75S
1992 K100RS
10Back to top Go down    Re: Vibration Reduction on Fri Sep 11, 2015 4:06 pm
The wheels are rebalanced every time I change the tyres. As Olaf says, it's probably the built-in 4k vibrator.
11Back to top Go down    Re: Vibration Reduction on Fri Sep 11, 2015 6:25 pm
My RS is good, The 'new' RT is good and smooth. My sidecar is terrible at around 3500rpm, the bars buzz, the fairing buzzes etc. One of todays projects is complete disassembly of the fairing on the sidecar bike and very careful reassembly to see if I can find the source of what's moving and buzzing with the motor.
Front wheel balanced finally yesterday, no more shake at 100kmh. It took a lot of weight, really I need to get a flat spot in the rim fixed, but for the moment it's not shaking anymore Smile. It's a custom 3 piece aluminium 15" wheel so I cant just buy another.
'87 K100RS/HRD sidecar (1100 motor)sc25
'92 K100RS-16v (Paint it Black)
12Back to top Go down    Re: Vibration Reduction on Sat Sep 12, 2015 1:54 am
Be made
Thanks for the posts guys. Front wheel balance is not an issue. Vibes are terrible when engine is cold, better once warmed up, really noticible around the 100k mark, non existent @ 160 +
That might be the answer !
Just stay above 160 :-) :pirat:
