1Back to top Go down    Water coolant o ring??.? on Sat Sep 19, 2015 9:51 pm
gabriel
Hi
Made an attempt yesterday to install the oil/water pump.
All was going well unti I tried to replace the water coolant o ring. The replacement part was purchased from Motobins.
I had difficulties trying to install the o ring. I had to strech it slightly to get it into the grove but when I let go, it wouldn't stay in position?
What should I do?
Is there something I've missed?
All comments will be appreciated.
Gabriel
2Back to top Go down    Re: Water coolant o ring??.? on Sat Sep 19, 2015 9:55 pm
Being a new O-ring, it's a tad smaller and does cause grief. You could try warming it in hot water or with a hair drier to make it a little more pliable. It's going to take finesse to get it to stay in place while fitting the pump.
2011 Moto Guzzi V7 Racer
3Back to top Go down    Re: Water coolant o ring??.? on Sun Sep 20, 2015 12:27 am
japuentes
Hi there, be aware that some o rings will shrink when heated with a hair dryer or heat gun.
Best regards
JAP
1988 K100RS SE/ABS
4Back to top Go down    Re: Water coolant o ring??.? on Sun Oct 04, 2015 2:31 pm
ReneZ
Can you stretch it a bit over a slightly larger bit (pill bottle or similar). Leave overnight and then quickly fit?
Greetings from Florida! Having a 'new' K :cyclops: Surprised-o:
Rene
BMW K100 - 1985 (0030029)
BMW K1200GT - 2003 (ZK01223)
