blacksmith adam
The bike started as normal, rode down the drive just going through the gate and the bike cuts out, grrrrrr!!!!! . Press the button, it fires for half a second and cuts out again.
I manage to get it ticking over (just) but the engine is cold and as soon as I put the choke on it cuts out, as soon as I turn the throttle it cuts out. The engine will only turn over when the throttle is open and will not fire until the throttle is closed. BIG Grrrrrr. Embarassed
So I’m assuming the throttle position sensor is broke.
Has any one had experience of this problem?
Is there a way of testing the TPS? Or am I on the wrong track.
Any ideas would be appreciated!
Have you been riding it before today?  Just done some work on it?  If so, what did you do?  Can you hear the fuel pump run?  How are the rubber bits?
What model?  What year?
1994 K75S
1992 K100RS
Using choke and opening throttle is the same thing, the 'choke' is just a means of getting some throttle opening. So opening throttle and opening choke will both have the same effect.
On some models [as far as I know its the 8 valve engines] we disconnect the TPS altogether when it goes wrong.
You seem to be saying you can start it and get a tickover. That implies fuel is flowing both at start and at run mode.
If yours is the K with the bolted down petrol tank the front left of the tank has the electrical connection to the fuel pump. It can get loose and produce a bad electrical connection effectively restricting or cutting off the fuel supply. If its loose open up the pins a little to make them a tighter fit. You will have taken this off when you removed the tank.
Another place I have come across a problem like this was the control unit under the seat having a badly connected plug. There is a little grub screw in this, make sure the connection is correct and the screw is in place. I imagine you have had this out so its a risk area.
That's two easy checks to start with.
1992 K100LT 0193214 Alaska Blue 101,000 miles
1984 K100RT 0022575 Baja Red bought 36,000 now 89,150 miles
1997 K1100LT 0188024 Mystic Red 58,645 now 69,000 miles
blacksmith adam
Thanks Olaf ill give those ideas a go
Thanks Point-seven-five, Its a K100rs 1986 I just changed the shims and balanced the TB then rode 130 miles in one hit with no problems, it ran a lot smoother, most of the rubber bits are new ish. I can hear the fuel pump and I don’t think it a lack of fuel problem.
Ok, just to clarify, the engine starts and runs with the throttle closed.  Dies when the throttle is opened.  Is that correct?
1994 K75S
1992 K100RS
blacksmith adam
@Point-Seven-five wrote:Ok, just to clarify, the engine starts and runs with the throttle closed.  Dies when the throttle is opened.  Is that correct?
yes, it runs with the throttle closed, but struggles which i think its down to being cold
It sounds like the mixture is running lean.  Opening the throttle either with the grip or the "choke" adds enough air to the mix to kill the engine.
Outside of the Engine Control Unit(ECU), the problem is possibly the result of several things.  First, poor fuel delivery, either because of a failing fuel pump or a plugged fuel filter.  It may also be that the fuel pressure regulator is not keeping the pressure in the rail high enough.
Second, engine temperature when cold is sensed and commands the ECU to enrich the mixture.  Could be a sensor failure or a bad electrical connection.
Last, there may be a vacuum leak that is allowing more air into the idle mix making it sensitive to additional air at the transition point to partial throttle.  Double check all the vacuum caps on the throttle bodies and all the vacuum hoses running around the engine.  You won't be the first one to leave a vacuum cap or hose off after doing a throttle body balance job.
1994 K75S
1992 K100RS
blacksmith adam
Thanks i'll work through those ideas
You can always pay my ferry fair...? No? Sad
Oh well. You can always phone me instead. Very Happy
blacksmith adam
@Dai wrote:You can always pay my ferry fair...? No? Sad
i'll ring mid morning, did'nt know what time you were working till
Work is always 15.30-00.00, so I'm usually available between 10.00-14.30.
Make sure the fuel pump is actually running when the engine is running and not just when the starter button is pushed.  They will idle for quite some time on the residual pressure after the pump stops.
Fixed it Rick. A good shove on the FICU plug worked wonders apparently.
@Dai wrote:Fixed it Rick. A good shove on the FICU plug worked wonders apparently.
Was that the same as on post 3?
You got it Olaf. Adam followed your instructions.
blacksmith adam
BIG Thanks to all! Problem fixed,
It was the control unit, after giving the connection a push and nothing changing, and going through everything else I gave it a frustrated wiggle and It worked. I cleaned the connections, there was a strange varnish like muck on it, put some electrical silicone grease on and it now works a treat!
Time to ride some more happy miles
