Go to page : 1, 2  Next
Bigsax
Bigsax
This is my 86 Kay. It came with the three spoke wheels, I think they are off a R1100. The after market exhaust was also on the bike when I got her, it has a really sweet note and adds more of a sporty look. (I think)
Pics of my K100 rear end tidying efforts so far P1040614
I removed the pannier brackets this weekend. I almost never use the panniers and if I plan on a road trip, it will only take half an hour to put them back. Is the gap between the duck tail and the side panel normal? It looks a bit big to me.
Pics of my K100 rear end tidying efforts so far P1040613
She came with an aftermarket shock, it has an adjusting knurled knob on it, damper adjustment? I have not played with it yet.
Pics of my K100 rear end tidying efforts so far P1040615
I cut down the rear mudguard for a sleeker look and removed the luggage rack.
Pics of my K100 rear end tidying efforts so far P1040616
Basic2
Basic2
Neat!
K100 Basic 2
11/1987 6308319K100CJ
Marakesh Red
looks as though you have benefited from the po's past mods
looks good to me
huge gap between exhaust and left side of bike and a collector system in place ...would like to see a better close up of that ...if its possible
the gaps on the side covers look about right to me for 85-86
Yeah looks good. The wheels are from a late model K75s, 91-96. The r1100 had 17" front and 18" rear. The front is definately from the K75s as it has the standard bolt pattern for K100 discs and the single spot calipers, the rear could be K1100 LT rear.
Any idea what breed the exhaust system is ?
Very neat bike.
Very nice, Bigsax.
looks great....does it handle ok with the larger wheels?....or are the tyres 110 and 140?....does look real tidy though
KKlompy Pics of my K100 rear end tidying efforts so far 2854237993
Pics of my K100 rear end tidying efforts so far Au-log10
Bigsax
Bigsax
charlie99 wrote:looks as though you have benefited from the po's past mods
looks good to me
Hi Charlie
The gap is really just the angle I took the pic from although I have noticed that I may have widened it by about 10mm by removing the pannier rail. The gap is 90mm from the wheel centre, 45mm from the tyre. I have taken some closer pics.
Pics of my K100 rear end tidying efforts so far P1040617
Pics of my K100 rear end tidying efforts so far P1040618
Bigsax
Bigsax
ainsjac wrote:Any idea what breed the exhaust system is ?
Very neat bike.
Hi Ainsjac
I have looked everywhere for a manufacturer on the exhaust but nothing found, sorry.
Bigsax
Bigsax
Klompy the grey brick wrote:looks great....does it handle ok with the larger wheels?....or are the tyres 110 and 140?....does look real tidy though
Handles well. The front is 100 90 18. Back 130 90 17
thanks mate ...some good visuals
Comberjohn
Comberjohn
Very pretty.
Health to ride.
Removing the pannier rails really cleans up the back end of the bike. As does removing the luggage rack.
Now, where did I leave my spanners?
Halo
Halo
Fantastic bike !
84 K100RS 0014803
93 FZR1000 EXUP
MikeP
MikeP
Very nice, looks very clean too.
Some sensible upgrades, among them a later main-stand. If it were mine, the next thing I'd do is look out for a set of K75 forks. Pics of my K100 rear end tidying efforts so far 112350
Alheng
Alheng
That is a very nice bike. And removing all the brackets really cleans it up.
Alheng
Alheng
MikeP wrote:Very nice, looks very clean too.
What's with the k75 forks?
Bigsax
Bigsax
looks good to me
Pics of my K100 rear end tidying efforts so far P1040619
Okay, so I have been loosing sleep over this and today fitted a 12mm spacer to really tuck the muffler in.
Is this K pox?
MikeP
MikeP
They're a bit better. All 75s had the 'S' forks and they fit in the K100 clamps. Probably more importantly, they have the integral brace so they are don't suffer the seal-popping twisting under heavy braking of the un-braced K100 forks.
The K100RS SE was fitted with them and so too were later "authority" spec K100RTs.
Is this K pox?
Depends.
Did you wake anyone else with your sleeplessness?
Did you have a spacer lying round the would 'do the job'?
Did you make a spacer to fit to 'do the job'?
Did you travel to buy a spacer to 'do the job'?
Did you get up at any time during the night because you remember seeing a piece that 'might do' to 'do the job'?
Did you google how big the spacer should be to 'do the job'?
Once you had fitted the space to 'do the job' did you rush to the computer, download said photo and post it here so we could all comment in as short a time as possible so you may be able to sleep tonight knowing you have 'done the job'?
Answer yes to any of the questions and the answer is J pox. Not quite K pox, but damn close.
Yes to two questions, ask for Clymer and a 10mm socket cause you are going to need them.
Then catch up on your sleep. You look like a wreck.
Not all the K75 had the s fork the early K75 had 41.3mm and later had 41.0mm and the later RT had the 41.3 also there is a bit of a mix there, be careful
Bigsax
Bigsax
rossco wrote:
Is this K pox?
Depends.
Haha Rossco, at least two of the above!
Hopefully I will sleep tonight... except now I have to worry about the bloody forks!!!!
Alheng
Alheng
Hijack!
Now that we are on the K75 forks, is there much difference in ride and power between the K100 and K75.
Now to keep it on track, the spacer looks slightly off centered. LOL!
From 0 to 160 kph there is little difference but after that the K100 just keeps pulling.
You also have to be a bit more vigilant and keep the revs up a bit more on the K75, when they reach 5000rpm they really get up and go where the K100 has good torque from much lower.
Bigsax
Bigsax
Alheng wrote:Hijack!
Now where did I put my calipers & laser level.....
Pics of my K100 rear end tidying efforts so far Brick110
I stole this image, let me know if you want it back.
MikeP
MikeP
In an effort to avoid going too far off track:
https://www.k100-forum.com/t5374-k100-or-k75#59993
Comberjohn
Comberjohn
Inspired by your photos, I've just removed the pannier rails and luggage rack. Blanked the holes on the seat hump.
Back end looks a lot less fussy.
Seems to be two schools of thought developing in the forum. One is taking bits off and the other is adding bits on.
And we all believe we are improving the breed in our own way.
Less is more.....until you need to carry stuff....Oh well there is always a backpack...
Alheng
Alheng
Think that I would struggle without panniers when I get back into a bike. On the FJ I at least had the top on all the time.
Bigsax
Bigsax
Alheng wrote:Think that I would struggle without panniers when I get back into a bike. On the FJ I at least had the top on all the time.
I just purchased an amazing backpack for $20 on fleabay.
Item number: 190734816296
It fits in the ducktail and still I have room for my other stuff, stubby holder, bottle opener, sunblock, hat etc.
That thing will never fly properly it hasn't got any tail feathers Very Happy
Themason
Themason
[quote="Alheng"]Hijack!
Now to keep it on track, the spacer looks slightly off centered. LOL![/quote]
Those are early Fichtel Sachs K100 fork legs and a very early K100 front fender, model year '83-'85. There is no cast fork bridge as one found on '88 and later Ks.
1986 R-80G/S w/1000 cc engine
"I've just removed the pannier rails and luggage rack. Blanked the holes on the seat hump.
Back end looks a lot less fussy."
...thanks Comberjohn. More ideas. Thanks alot! Evil or Very Mad
blakey wrote:"I've just removed the pannier rails and luggage rack. Blanked the holes on the seat hump.
K100/2 to be for sale soon. No blanking off baggage holes.
Rear cowling is hole free.
Nekkid.
Red.
Big, that zorst sitting next to the 3 spoke just looks the biz.
With the clamps and all shiney.
Me likey
Bigsax
Bigsax
rossco wrote:Big, that zorst sitting next to the 3 spoke just looks the biz.
Me likey
Thanks Rossco, not my doing, but will lap up the praise Very Happy
At the risk of sounding like a total t**ser, I have just ordered black carbon fibre contact adhesive sheeting to wrap around the battery.
Oh man the K pox....
Contry to what is being touted as sleep deprivation I would say K pox is the product used prior to springing in the slumber department, so it's quite possible that sleep will give you a geater opportunity to conjure up a newer vision of your bike, to quote a movie the castle he's an Idea's man he is (once absorbed by the Kpox) that is. And all that conjuring is also from the Castle as they say tell him he's dreaming. Seems to me K Pox is good for you.
Bigsax
Bigsax
Pics of my K100 rear end tidying efforts so far P1040629
The battery looked ugly to me, so I invested $2 on black carbon fibre plastic sheeting.
Got to type this quick.. I think I see the men in white coats coming for me........
I gave my Motobatt a coat of black spray can and it disappeared into the hole under the seat. Beats me why they make them like that.
GerryP
GerryP
Bigsax - That's a good-looking bike...
I had similar thoughts about my LT, so I took off the top box and rack, then I slimmed the seat down.
I can't take the panniers off, I use them too much.
Currently I'm looking at making a panel to cover the area between fairing/side panel/sub-frame support strut or perhaps right up to the panniers but after messing around with sheets of cardboard I can't find a way to make it work.
Safe riding Cool,
Gerry Parnham
K1100LT (1993) in Silk Blue/Cream
http://gerryparnham.com
Tenox
Tenox
And now you said it! Had the whole bike in pieces and it did not come into my mind that one could paint the battery... Well, next winter then.
BMW K100RT Scrambler (86)
Bigsax
Bigsax
GerryP wrote:Bigsax - That's a good-looking bike...
Good luck with that Gerry. You could try getting a sheet of plaster, like the ones used to make casts for broken limbs. Cover the bike in plastic and try moulding it where you want it.
Funny, here in Australia we are stripping off panels to cool the bike down!
42Back to top Go down   Pics of my K100 rear end tidying efforts so far Empty Rear end update Mon Jan 05, 2015 4:37 am
Bigsax
Bigsax
I lowered the rear end by finding a rear shock absorber that is 30mm shorter than standard and installed it.
It has a firmer and tighter feel about it. I love the lower look.
I also dropped the front triple clamp by 15mm.
The bike handles great, fantastic through the twisties. it is a little hard on the rear end over bumps and I have removed the center stand as it is now impossible to use.
Pics of my K100 rear end tidying efforts so far P1060012
good result mate
happy riding to you
RicK G wrote:I gave my Motobatt a coat of black spray can and it disappeared into the hole under the seat. Beats me why they make them like that.
A bit like Ohlins coloured springs, eh?!
I left my Motobatt as yellow as it comes and it gets to me every time I walk back towards the bright red bike. Now it's in a shed near Brissy not bothering me for nine more months...
45Back to top Go down   Pics of my K100 rear end tidying efforts so far Empty Update Wed Apr 29, 2015 12:09 am
Bigsax
Bigsax
Pics of my K100 rear end tidying efforts so far P1060310
Pics of my K100 rear end tidying efforts so far P1060311
Pics of my K100 rear end tidying efforts so far P1060312
Pics of my K100 rear end tidying efforts so far P1060313
I have dropped the rear end by fitting a shock absorber 35mm shorter. It has less travel obviously and makes the ride much firmer.
I have tried adjusting the handlebars by dropping them accordingly but found that the best riding position for me is with them at the highest point on the forks.
I have mostly just removed things pegs, z bars, lower fairings etc and have really only added a Laminar lip and changed the rear indicators.
I love the look of this bike and have tried to make any changes look as factory as possible
Very nice clean looking bike. I like the rear blinkers. Been looking for something like that for mine. Where did you get them from?
 Pics of my K100 rear end tidying efforts so far Austra12    Fuel:  95 Octane
Bigsax
Bigsax
Nice work on the bike.
Just bought meself a set of those indicators also.
I like the idea they sit pretty flush and have the added advantage of being seen from the side and rear. And not LED.
Bigsax
Bigsax
rosskko wrote:Nice work on the bike.
Yep, and they are the right colours for the bike era, they tick all the box's.
50Back to top Go down   Pics of my K100 rear end tidying efforts so far Empty tidy bike Wed Apr 29, 2015 11:54 am
td5
td5
Big Sax,
What do you do to get the engine so clean, it looks brand new!
