1Back to top Go down    coolant overflow! on Mon Nov 30, 2015 3:31 pm
eire1400
eire1400
I want to replace my coolant overflow tank and move it up close to the down tube on the right (behind airbox snorkel).
I've seen a few examples and was thinking of going with a 750mm steel sports bottle. Question is anyone got any ideas for connecting the hose? Obviously I'm going to have to drill a hole at the bottom, but after that how to connect hose? Thanks in advance.
2Back to top Go down    Re: coolant overflow! on Mon Nov 30, 2015 3:41 pm
The ideal is if you have a spigot or short stub protruding from the new coolant tank that will accept the connecting hose from the radiator. You just may be able to get someone to do some welding but I would think either stainless steel or plastic may work and even better if you could use a stock item from some other manufacturer.
You will need a spigot or short length of pipe protruding from the bottom of the new 'tank' of the same dimensions as the one on your K coolant bottle. I imagine a sports bottle is too thin to be welded.......but maybe some other motorcycle coolant expansion tank?
1997 K1100LT 0188024 Wotan Mystic Red 58,645 now 87,980 miles
1983 K100RS 0011175 Fricka 29,000 miles Damn K Pox
3Back to top Go down    Re: coolant overflow! on Mon Nov 30, 2015 3:55 pm
Chocolate
Chocolate
Should be easy, you will find that in any country in a homedepot/construction market.
Plug & Play
4Back to top Go down    Re: coolant overflow! on Mon Nov 30, 2015 4:46 pm
Motorbike Mike
Motorbike Mike
If the bottle is made of aluminium you could drill a hole to take a short piece of alloy tube and "solder" it in yourself with Lumi-weld. It can be done with some care and a blow lamp. Try it on some scrap first.
http://www.ebay.co.uk/itm/Lumiweld-5-Rod-Kit-Low-Temp-Aluminuim-Repair-/260531563568?hash=item3ca8e42c30:g:3~oAAOxyJX1TCfx3
Here's a practical example.
5Back to top Go down    Re: coolant overflow! on Mon Nov 30, 2015 5:52 pm
eire1400
eire1400
Espresso wrote:Should be easy, you will find that in any country in a homedepot/construction market.
Plug & Play
The very thing.  What would you call them?  What they used for?
6Back to top Go down    Re: coolant overflow! on Mon Nov 30, 2015 6:14 pm
Chocolate
Chocolate
# Hello eire1400, sorry I don't know the name even in German :-) I used to describe what I want.
We use it to catch rain in a barrel and I use it for my drinking bottle on long journeys with my bicycle on the top is a holle and at the bottom a kind of drinking straw.
What I googled was "tube to bottle" something like that, I'm sure you find better English words :-)
And in the end, a good German or Irish beer barrel hast the same function!
http://illiweb.com/fa/pbucket.gif
7Back to top Go down    Re: coolant overflow! on Mon Nov 30, 2015 6:35 pm
If you can't find one of those fittings, you could use a tyre valve without the insert.
8Back to top Go down    Re: coolant overflow! on Mon Nov 30, 2015 9:25 pm
Looks like Espresso got a right dose of Kork when he lived over here for 4 years......
9Back to top Go down    Re: coolant overflow! on Tue Dec 01, 2015 3:09 am
Chocolate
Chocolate
# Yes Olaf,
learned a lot in Ireland and I enjoyed very friendly people and girls :-)
I was thinking of a very easy other way, to connect a tube
A screw with a hole, you could even use the parts from the braking system, if you have left.
10Back to top Go down    Re: coolant overflow! on Tue Dec 01, 2015 6:19 am
eire1400
eire1400
Thanks for the excellent suggestions folks. I'm thinking similar to the gold bottle in Espresso  6th post might be easiest way around it!
