1Back to top Go down   Instrument upper cover needed Empty Instrument upper cover needed on Mon Dec 28, 2015 8:42 am
nino
Hello everyone, I need front instrument cover for k 100 8 V 1984. Ih has to be without dents on plastic and glass. Thanks
2Back to top Go down   Instrument upper cover needed Empty Re: Instrument upper cover needed on Tue Dec 29, 2015 3:13 pm
walfish
walfish
is this what you're after?
Instrument upper cover needed 20151212
Instrument upper cover needed 20151213
Instrument upper cover needed 20151214
Instrument upper cover needed 20151215
Your's for the price of carriage.
Instrument upper cover needed 22936
Instrument upper cover needed Uk-log10 88 K 100  0033026
                            92 K 1100 LT  6455097
3Back to top Go down   Instrument upper cover needed Empty Re: Instrument upper cover needed on Tue Dec 29, 2015 4:39 pm
nino
Yes, upper part of instrument box. Thanks
4Back to top Go down   Instrument upper cover needed Empty Re: Instrument upper cover needed on Tue Dec 29, 2015 4:46 pm
nino
@nino wrote:Yes, upper part of instrument box. Thanks
Email sent
5Back to top Go down   Instrument upper cover needed Empty Re: Instrument upper cover needed on Tue Dec 29, 2015 5:06 pm
walfish
walfish
Hi Nino
           will post the cluster as is, it is not complete there are some parts missing, just use whatever you need and pass on to someone who needs other bits.
6Back to top Go down   Instrument upper cover needed Empty Re: Instrument upper cover needed on Tue Dec 29, 2015 6:05 pm
Be aware that a -84 have a 7 screw housing (unless it's produced very late in the year).
The housing in the pictures is a -86 year model (or later) which have a 9 screw housing.
To make the earlier internals fit in the newer housing mods is needed on fuel level PCB and some of the plastic on the speedo.......time to search for Your Dremel.
One could also search a PCB for the early fuel level system which is made for the 9 screw housing.
7Back to top Go down   Instrument upper cover needed Empty Re: Instrument upper cover needed on Tue Dec 29, 2015 7:49 pm
nino
Thanks Wally. Inge, I already use 86. instruments with 84. Pcb adapted to early fuel level sender in tank and so far it works well. (fuel warning comes on 6 ltrs)
8Back to top Go down   Instrument upper cover needed Empty Re: Instrument upper cover needed on Wed Mar 02, 2016 5:04 am
Viper357
Viper357
Hey Nino
Did the instruments you get have a LED clock? I am desperate for one for my K100RS
Gary
1985 BMW K100RS
9Back to top Go down   Instrument upper cover needed Empty Re: Instrument upper cover needed on Wed Mar 02, 2016 6:07 am
10Back to top Go down   Instrument upper cover needed Empty Re: Instrument upper cover needed on Wed Mar 09, 2016 9:04 am
Viper357
Viper357
Thanks RickG for the heads up
Deal was made and I should have the 'new'clock soon . Will make the old girl back to original
Gary
1985 BMW K100RS
