1Back to top Go down   K100 stuff for sale in Sydney Empty K100 stuff for sale in Sydney on Thu Jan 14, 2016 8:17 am
In used condition
Rear tail section with indicators and wiring harness plus mount for top box
Top box with lock (key is around somewhere)
Dual seat with mounting hardware (no tears)
Seat base (mounts to frame)
Black exhaust heat shield (small damage to the very end which can easily be put right)
Plastic trim panels (L & R) which wrap around frame head (two sets available)
Rear mudguard (Two available)
Mudguard extension (two available)
Inner trim insert (fits between leg and frame to isolate engine heat)
Electrical fuse box with lid
Electrical fuse box without lid
Dashpad, which houses ignition key etc. (Has a hole drilled through the dash padding)
Fork leg plastic surrounds which protect trim panel from forks (Two available)
Rear footpegs (Rubber is supple - bolt straight on)
Right mirror housing complete with cracked glass in gray
Right mirror housing complete but the halves of the shell have come apart. No glass in black.
Leg inserts (Left and right)
Civilian engine protection bars (Left and right)
Authorities vehicle engine protection bar (Right only with mounting hardware)
Authorities vehicle rear protection bars (Left and right with mounting hardware)
Throttle assembly (mounts on handlebars)
Clutch assembly (mounts on handlebars)
Front master cylinder
Rear master cylinder
Dual seat plastic handles (Pair)
ECU plastic cover
Dash support (which fits under the windscreen)
Shock
Battery tray
Brembo caliper
Brake lines
Glove box pocket frames (Two sets available)
Glove boxes (1 right side in great shape, 1 right and 2 left in usable condition)
Petrol tank rubber grommet (fits around frame underneath tank)
Radiator fairing and grill (several small cracks in the fibreglass, but easily fixed)
BMW K100RS handlebars
Rear wheel centre cap
Air intake tube
Various sets of cables
Instrument clusters rubber bushings
Mirror pod hardware - mounts to fairing (Left and right set)
Indicator lenses (Left and right)
Windscreen with mounting hard (Aftermarket tall style used by NSW Police)
Windscreen with mounting hardware (Stock screen with some yellowing, but otherwise in good shape)
Rear indicator housing (Two sets of left and right available)
Main wiring loom to fits 1988 K100RT
In new condition
Chrome exhaust heat shield
Triple tree clamp
Footrest plate - Ribbed style (Left and right)
Oil pan
Oil pan cover
Handlebar clamp caps (Set)
Taillight lens assembly with mounting screws
Pictures can be found by clicking this link:
https://s482.photobucket.com/user/junglegeorge45unglegeorge45/library/
I need this lot gone by the 18th, and would prefer a job lot, but I'm open to suggestions so feel free to get in touch.
Cheers, Alex.
2Back to top Go down   K100 stuff for sale in Sydney Empty Re: K100 stuff for sale in Sydney on Thu Jan 14, 2016 4:21 pm
Rear footpegs
Tail light
Possibly the shock
PM sent
  K100 stuff for sale in Sydney Austra12    Fuel:  95 Octane
3Back to top Go down   K100 stuff for sale in Sydney Empty Re: K100 stuff for sale in Sydney on Fri Jan 15, 2016 3:42 am
beanoldboy
beanoldboy
hello mate ,  may ive the rs bars and a/left pocket lid please ,
may i see the triple tree clamps and new heat shield please?
N
http://www.airware.com.au
4Back to top Go down   K100 stuff for sale in Sydney Empty Re: K100 stuff for sale in Sydney on Fri Jan 15, 2016 3:43 am
Hi mate, pictures of everything are in the link I posted
5Back to top Go down   K100 stuff for sale in Sydney Empty Re: K100 stuff for sale in Sydney on Fri Jan 15, 2016 5:32 pm
Also.... Instrument clusters rubber bushings
Hopefully they're in better condition than mine currently.
Just waiting on some prices. I can get my daughter to pick up asap
