1Back to top Go down   Wanted, Cams for K100RS 16V Empty Wanted, Cams for K100RS 16V on Thu Jan 14, 2016 10:31 pm
Bet that got your attention but what I really want (as against what some think I need) is a set of good condition K100RS 16V cams.
If you study this set of numbers you will see why.
Wanted, Cams for K100RS 16V Cam_ti10
Last edited by RicK G on Fri Jan 15, 2016 7:19 am; edited 1 time in total (Reason for editing : Sanity prevails)
2Back to top Go down   Wanted, Cams for K100RS 16V Empty Re: Wanted, Cams for K100RS 16V on Thu Jan 14, 2016 11:56 pm
Numbers are 38, 24, 36
3Back to top Go down   Wanted, Cams for K100RS 16V Empty Re: Wanted, Cams for K100RS 16V on Fri Jan 15, 2016 2:37 am
ainsjac wrote:Numbers are 38, 24, 36
That is a nice set of numbers. Is the other leg the same?
4Back to top Go down   Wanted, Cams for K100RS 16V Empty Re: Wanted, Cams for K100RS 16V on Fri Jan 15, 2016 3:23 am
There are 5 more legs
5Back to top Go down   Wanted, Cams for K100RS 16V Empty Re: Wanted, Cams for K100RS 16V on Fri Jan 15, 2016 8:41 pm
some pretty strange number there rick
im quite amazed at the late inlet opening on the k1100 ...closing seems ok though ...
although the short duration of the k1 inlet ...the opening seems about right   the exhaust looks fine
yes ?
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%OWanted, Cams for K100RS 16V Au-log10
6Back to top Go down   Wanted, Cams for K100RS 16V Empty Re: Wanted, Cams for K100RS 16V on Fri Jan 15, 2016 10:07 pm
It's the reason that the K1100 doesn't have anywhere near the low down torque the K100 has and thats what is missing when I tow the trailer. I really need to work the clutch to get moving.
And according to RealOEM the AU K1100 has very different cams with a 256 overlap as to 284 for the EU models.
7Back to top Go down   Wanted, Cams for K100RS 16V Empty Re: Wanted, Cams for K100RS 16V on Fri Jan 15, 2016 10:23 pm
It's not the only difference between aussie and eu models, also ekshaust is different...both 2V and 4V.
Aussie cams is the same as US models.
8Back to top Go down   Wanted, Cams for K100RS 16V Empty Re: Wanted, Cams for K100RS 16V on Fri Jan 15, 2016 10:29 pm
Do you want to sell the cams out of your SE Laughing   But on a serious note do you know where I can get a set of the EU cams.
I could advance my inlet cam 2 teeth but then the top end will suffer very badly.
9Back to top Go down   Wanted, Cams for K100RS 16V Empty Re: Wanted, Cams for K100RS 16V on Fri Jan 15, 2016 10:35 pm
Sorry, no idea where to buy......you have to watch Ebay....especially German part......."nockenwelle".
10Back to top Go down   Wanted, Cams for K100RS 16V Empty Re: Wanted, Cams for K100RS 16V on Fri Jan 15, 2016 10:45 pm
Thanks I will do that just I only speak Aussie version of English so I tend not to go there.
11Back to top Go down   Wanted, Cams for K100RS 16V Empty Re: Wanted, Cams for K100RS 16V on Fri Jan 15, 2016 10:58 pm
Chocolate
Chocolate
Hello!
If you are looking for cams, The search name should be:
BMW K1100LT K1100RS NOCKENWELLEN Nockenwelle Camshafts 2 Stück Nocken Wellen
http://www.ebay.de/itm/BMW-K1100LT-K1100RS-NOCKENWELLEN-Nockenwelle-Camshafts-2-Stuck-Nocken-Wellen-/111869214672?hash=item1a0becbfd0:g:1TUAAOSwLN5Wj-OD
The man who is selling is very helpful, I buy a lot from him, you can make him a price offer, shipping is around 30-40€ to UK.
There are other cams for the K1100 in German eBay.
If you need help, tell me, I could buy and ship, but ask the seller from Hamburg he will probably too.
12Back to top Go down   Wanted, Cams for K100RS 16V Empty Re: Wanted, Cams for K100RS 16V on Fri Jan 15, 2016 11:00 pm
@RicK G wrote:Thanks I will do that just I only speak Aussie version of English so I tend not to go there.
Shouldn't be any problem...I've seen on some pages....."wir sprechen auslandisch". Razz
13Back to top Go down   Wanted, Cams for K100RS 16V Empty Re: Wanted, Cams for K100RS 16V on Fri Jan 15, 2016 11:28 pm
Wanted, Cams for K100RS 16V 44271
I see there are some to choose from, are the EU version of the K100 16V the same?
14Back to top Go down   Wanted, Cams for K100RS 16V Empty Re: Wanted, Cams for K100RS 16V on Fri Jan 15, 2016 11:38 pm
@RicK G wrote:, are the EU version of the K100 16V the same?
Same as?
K11 is all similar.....EU/K1 is more aggresive.
But K11 and EU/K1 with the same duration have different part #.
It seems like it's more to it than meets the eye....and you can't just throw some EU/K1 cams into your K11 that easy.
15Back to top Go down   Wanted, Cams for K100RS 16V Empty Re: Wanted, Cams for K100RS 16V on Fri Jan 15, 2016 11:52 pm
Thanks Inge
@Espresso Thanks, those cams looked a bit rough on one of the journals but there are others I am looking at.
16Back to top Go down   Wanted, Cams for K100RS 16V Empty Re: Wanted, Cams for K100RS 16V on Sun Jan 17, 2016 9:02 pm
hey rick ...just thinking aloud here ....but
couldn't you redrill the dowel for the cams in the cam sprocket to be 16 degrees advanced on the inlet and 14- 16  degrees retarded on the exhaust ?whichever way round it works out anyhow ..
that might give you something better ?  with out too much playing around ??
just an idea
17Back to top Go down   Wanted, Cams for K100RS 16V Empty Re: Wanted, Cams for K100RS 16V on Fri Feb 19, 2016 4:06 pm
Brad-Man
Brad-Man
@charlie99 wrote:hey rick ...just thinking aloud here ....but
just an idea
I was thinking the. same thing..duration is the same on both intake and exhaust between the two sets...
That said there is a "cafe" k1100LT on Craigslist locally and I may be suffering from KPox...
The fact that I happen to have a complete K1004v engine and tranny w/paralever that I got for my 85 K has me thinking... Especially because I have the RS 3 spokes...
Wanted, Cams for K100RS 16V Usa-lo10
18Back to top Go down   Wanted, Cams for K100RS 16V Empty Re: Wanted, Cams for K100RS 16V on Fri Feb 19, 2016 10:07 pm
just an idea
woohoo !
