1Back to top Go down   OK, HTF do I get the headlight lamp out? Empty OK, HTF do I get the headlight lamp out? on Mon Feb 22, 2016 4:48 pm
SniperX
SniperX
I tried pulling the plug off the lamp, but it is either stuck, or I am not seeing some clip or something. I know on H4's there is usually a spring clip affair to hold the lamp in it's mooring, but the lamp connector has always come off everything else I have ever changed one on. The clip usually looks like a springy U which locks into a couple slides on the lamps reflector. What am I missing? Oh, and do the knobs near both right and left adjust the headlamps alignment? If so which is which?
1972 BMW 3.0CSL, 1985 BMW Dinan 535i, 2001 Honda XR400R (plated), 1985 K100RT, 2004 ZX3 Focus, 1991 Dodge Power Wagon 4x4. 1977 Plymouth Trailduster 35K original miles!
Kyle10
Kyle10
It's stuck. Doosh it w/WD40 or the like and give it a spell to soak in.
1985 K100rt 0052183
1983 Honda VF750 007713
SniperX
SniperX
@Kyle10 wrote:It's stuck. Doosh it w/WD40 or the like and give it a spell to soak in.
Will do, so it removes as normal?
Kyle10
Kyle10
Top Left: Vertical
Lower Right: Horizontal
Ah, there is a locking clip that needs to be removed. Rotate the clip and it will come out. You've taken off the rubber boot/protector, right?
1985 K100rt 0052183
SniperX
SniperX
@Kyle10 wrote:Top Left: Vertical
No because I can't get the plug off the back of the lamp yet....it's soaking in WD though as we speak.......
@Kyle10 wrote:Ah, there is a PITA locking clip that needs to be removed. Rotate the clip and it will come out. You've taken off the rubber boot/protector, right?
Just thought I'd correct that Very Happy
Kyle10
Kyle10
Said offending clip:
OK, HTF do I get the headlight lamp out? 20160210
1985 K100rt 0052183
Kyle10
Kyle10
You've bought a K. I hope you have patience and like to sip beer.  Beer drinker
1985 K100rt 0052183
SniperX
SniperX
@Kyle10 wrote:Said offending clip:
That whole big white thing is the locking clip? Hard to tell from the photo. And do I rotate it left to off then back right to lock?
On early Ks, there's a locking ring to hold the H4 in place.  Turn it counterclockwise. Later ones have a clip.
If the plug won't come off of the back of the H4 then it is probably due to corrosion.  It will come off, eventually.
Kyle10
Kyle10
The white plastic holds the retainer spring, which is metal.
I can't tell you for certain which way to rotate it, as it's been some time for me and it's buried beneath a heluva lot of plastic, etc.
1985 K100rt 0052183
Kyle10
Kyle10
Duck to the rescue. Thanks, D.
1985 K100rt 0052183
SniperX
SniperX
@duck wrote:On early Ks, there's a locking ring to hold the H4 in place.  Turn it counterclockwise. Later ones have a clip.
got the plug off, a and the boot, stand by......
SniperX
SniperX
Success! Thanks! Oh, best to wear gloves....OK, HTF do I get the headlight lamp out? 12764498_974726789287148_5202378109316110006_o
16Back to top Go down   OK, HTF do I get the headlight lamp out? Empty Got the LED lamp in on Mon Feb 22, 2016 5:35 pm
SniperX
SniperX
Wow, nice pure white! WAY brighter than the stock H4 Halogen. We shall see how it works tonight when it is dark and I can get a real feel for the pattern and brightness. Cheers!OK, HTF do I get the headlight lamp out? 71BDtjDu7aL._SX522_
Kyle10
Kyle10
Picture comparo, please. Been contemplating this for awhile.
1985 K100rt 0052183
I run 100/55W or 100/90W Xenon cheapos from Fleabay.  Very white and the high beam is good enough to do at least 85mph at night.
The "worst" one I had lasted about 15K before burning out but at $8/pair I can afford a spare in the tail cowl.
(DO NOT use higher than 60W bulbs without headlight relays and beefed up wiring.)
19Back to top Go down   OK, HTF do I get the headlight lamp out? Empty Re: OK, HTF do I get the headlight lamp out? on Mon Feb 22, 2016 11:49 pm
SniperX
SniperX
@Kyle10 wrote:Picture comparo, please. Been contemplating this for awhile.
Well, I can't do a before because I had to do this while the take was off or so I thought. So, I would have to swap the stock one back in to do a before and after shot. BUT I can do pics of what it looks like when I finish the stuff I am doing now. I will say it is much better white light, and it is very noticeably brighter, and the beam pattern is a lot better. Somewhat like having a set of LED fogs on that have the same cutoff as the low beam. Much wider light pattern. Plus on high beam it looks like both high and low beam stay on. Much more light than the Sylvania 55/60 that was in there. I'll also say, one of the reason the stock hi low switch degrades is people want more light so install a 90/130 or much higher draw halogen and it burns up the switch. These draw about 1/4 what a stock 55/60 does. So my new switch should last another thirty years.
20Back to top Go down   OK, HTF do I get the headlight lamp out? Empty Re: OK, HTF do I get the headlight lamp out? on Mon Feb 22, 2016 11:51 pm
SniperX
SniperX
@duck wrote:I run 100/55W or 100/90W Xenon cheapos from Fleabay.  Very white and the high beam is good enough to do at least 85mph at night.
Yes, a relay is the main point to keeping your headlight switch from going thermo nuclear due to way too much amperage when using those lamps.
21Back to top Go down   OK, HTF do I get the headlight lamp out? Empty Re: OK, HTF do I get the headlight lamp out? on Tue Feb 23, 2016 12:42 am
JR_K100RS
JR_K100RS
I'm also thinking of doing this upgrade , one question if I may , there is a metal shield inside the reflector that sits in front of the bulb , does this stay in ?
John Re
SniperX
SniperX
@JR_K100RS wrote:I'm also thinking of doing this upgrade , one question if I may , there is a metal shield inside the reflector that sits in front of the bulb , does this stay in ?
John Re
No there isn't a reflector in the stock housing.
SniperX
SniperX
OK a bit off topic, butnwherebisnthe flasher relay on the k100rt?
Its in the electrical box under the back of the tank
25Back to top Go down   OK, HTF do I get the headlight lamp out? Empty Re: OK, HTF do I get the headlight lamp out? on Wed Mar 23, 2016 10:10 pm
This link is on the Portal tab. You'll find the electrical relay box diagram there.
EFI/Electronic ignition troubleshooting
  OK, HTF do I get the headlight lamp out? Austra12    Fuel:  95 Octane
