You can now order the forum stickers. Login and go to the "members only" forum. This is not available for guests yet....
1Back to top Go down    Intermittent electrical gremlin on Sun Mar 20, 2016 1:03 am
Rockman
I suspect the ignition switch with this one but before I pull it apart I thought I'd ask for other suggestions;
-first time: started and cut out again almost straight away on the Snowys trip. It would crank over but no go. I turned the kill switch off and on, no effect. Then the ignition switch off and on. Started immediately, hasnt done it again since.
-second time: friday this week. Clock missing segments. I stopped, did some stuff, then restarted. Clock came good.
-third time: yesterday and this morning. No clock at all. Went for a ride. Restarted, clock is now all good.
So the question. Is this the ignition switch starting to play up, or a bad connection in the instruments, or something else? Its not serious yet, but is starting to develop.
88K100RT
2Back to top Go down    Re: Intermittent electrical gremlin on Sun Mar 20, 2016 2:38 am
Sure sounds like the ignition switch Phil but the clock probably needs cleaning as well. You can get the LCD of the circuit board 4 small screws I think then clean the contact surface with a soft white pencil eraser on the LCD and circuit board then replace it. It will probably work well again for another 30 years.
If everything seems under control then you aint goin fast enough:- Mario Andretti
Bikes 1986 K100RT, 1993 K1100 LT, 1994 K1100 LT, 1993 K75 RT, 1996 K75RT, 1986 K75 GS, 1979 Z1300 Kawasaki X 2 & 1976 SR 500 Yamaha for now
3Back to top Go down    Re: Intermittent electrical gremlin on Sun Mar 20, 2016 6:21 pm
Rockman
@RicK G wrote:Sure sounds like the ignition switch Phil but the clock probably needs cleaning as well. You can get the LCD of the circuit board 4 small screws I think then clean the contact surface with a soft white pencil eraser on the LCD and circuit board then replace it. It will probably work well again for another 30 years.
Thanks Rick. I'll start there and see what happens.
