1Back to top Go down   Probs with K75 Empty Probs with K75 Mon Mar 28, 2016 4:11 pm
Working on it Very Happy
It's my old K75S, finally found time to check things out.
Has problems with starting, but when it runs, too much fuel.
Did a lot of things, been there done that....even got a new tempsensor.
Here's the trick (hope get it) measuring the wires gives broken wires to the sensor Rolling Eyes
Damn, now remove all the hardware to acces the sensor and check the loom.
Will get pics, and updates too Beer drinker
By the way, friend has a K75 too, ran bad, no spark on middle cilinder.
Got a new coil, new cable, checked the correct connections....all good, even got spark, but no running on middle cilinder.
Stop guessing, ignitionbox from a K100 fits too Probs with K75 178468 Bugger....
Placed a K75 ignitionbox and now running like new Smile
Probs with K75 Eu-log10  K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
2Back to top Go down   Probs with K75 Empty Re: Probs with K75 Mon Mar 28, 2016 5:14 pm
Probs with K75 10644325_1159219130769058_3171750113498321147_o
Probs with K75 12909627_1159219134102391_2124359324968582884_o
Zero from pin 10 to tempconnector, zero from temprelais to tempconnector. Think have the bugger Smile
3Back to top Go down   Probs with K75 Empty Re: Probs with K75 Mon Mar 28, 2016 6:32 pm
Got a spare loom from a friend, this one is good, all connections are perfect Smile
Probs with K75 12891157_1159271380763833_7689054345219077507_o
4Back to top Go down   Probs with K75 Empty Re: Probs with K75 Mon Mar 28, 2016 7:41 pm
Zero equals open circuit, not much fun, good job you have a friend with a spare.
5Back to top Go down   Probs with K75 Empty Re: Probs with K75 Mon Mar 28, 2016 8:05 pm
Actually, Zero equals CLOSED circuit indicating continuity
If Wheeldigger is actually measuring 0.0 ohms on both of those wires then I would say they are ok.
If he is just using the term zero to mean he's getting nothing on those circuits then its a little confusing.
Continutity/closed circuit/conductivity = no or very tiny resistance. DMM displays 0.0 or <0.5 ohms (depends which scale you use).
No continuity/open circuit/no conductivity = infinite resistance. DMM displays 1
 Probs with K75 Austra12    Fuel:  95 Octane
6Back to top Go down   Probs with K75 Empty Re: Probs with K75 Mon Mar 28, 2016 8:11 pm
I was thinks Zero Volts nige
7Back to top Go down   Probs with K75 Empty Re: Probs with K75 Mon Mar 28, 2016 9:02 pm
Keith, volts yes, but WD's second photo shows he's measuring between the FICU plug and the sensor connector. No Vs there as its all disconnected from the system. The test is for continuity and the measurement is ohms.
Wheeldigger, I think you would be better to reinstall and reconnect the temp sensor and measure the resistance on the 200 kilohm range between pin #10 on the FICU plug and earth. But first clean the threaded connection on the sensor and the engine block.  You should be measuring around 2.5 kilohms (at 20oC). This tells you firstly that the sensor is functioning as it should plus you have continuity between the sensor and the FICU plug connections.
The sensor earths thru the threaded body to the engine. A lot of issues come from corrosion here due to disimilar metals. The FICU thinks it high resistance and pumps in too much fuel at startup.
Another thing to consider is that the new sensor is kaput. A member here had this happen just recently. To test the new sensor Out-Of-The-Box, measure kilohms between the top connection (there are 2) and the threaded base (about 2.5 kilohms). This saves a lot of trouble and frustration if it turns out to be a dud sensor.
8Back to top Go down   Probs with K75 Empty Re: Probs with K75 Tue Mar 29, 2016 1:34 am
Thanks all, had a long journey to find the problem.
Altough it was in my mind that it must be the loom, not in the hands, didn't have time to work on the bike.
Temp sensor is new, and good. Just like lots of other parts.... Bugger kept me busy Wink
In between EFI conn - temp conn, and temp conn - relais conn is no connection anymore, endless resistance, broken wires.
The new loom/part feels soft and easy to bend, the old one is hard, feels like willing to break, Guess our new fuel (not much choice) and being old made the crap complete.
9Back to top Go down   Probs with K75 Empty Re: Probs with K75 Thu Mar 31, 2016 5:17 pm
Bad loom replaced, some other things fixed.
Now waiting for some parts to come, and next saturday buy some parts.
Should be running on sunday Smile
10Back to top Go down   Probs with K75 Empty Re: Probs with K75 Thu Mar 31, 2016 7:54 pm
Good news Wheeldigger, we await the first report on your ride.
11Back to top Go down   Probs with K75 Empty Re: Probs with K75 Fri Apr 01, 2016 5:35 pm
New battery, new coolant, some new connectors....
Some little electrical problems left, but going....been sitting too long without running Smile
Fan gets a new manual override, and upgrade with daylight running lights.
Have to find a way to disable +12V to the clock, because replaced the clock with LED Volt-meter, drains the battery.
Tomorrow will get my old parts from my old shed, get the bike together cheers
12Back to top Go down   Probs with K75 Empty Re: Probs with K75 Fri Apr 01, 2016 5:51 pm
Remove the Red/White wire on Pin 1 of the cluster connector and re-wire that pin up to the Green/Black wire on Pin 6.
13Back to top Go down   Probs with K75 Empty Re: Probs with K75 Fri Apr 01, 2016 8:30 pm
Rob what will that do? Is pin 6 switched?
Wheeldigger I hope you can take a pic of that LED Voltmeter for us, sounds like a great use for the clock space.
14Back to top Go down   Probs with K75 Empty Re: Probs with K75 Fri Apr 01, 2016 8:39 pm
K75ster, that's the intention. Switched 12V gets applied to the voltmeter instead of constant 12V.
15Back to top Go down   Probs with K75 Empty Re: Probs with K75 Fri Apr 01, 2016 8:45 pm
Ok Good to know makes it just like the others then. (bikes that have standard volt meters That is)
16Back to top Go down   Probs with K75 Empty Re: Probs with K75 Sat Apr 02, 2016 5:00 am
Probs with K75 10604596_907109125980061_8719190872083523405_o
If there is no clock in the cluster, a black plastic cover is on the inside wich fits like the clock.
I used that one asplaceholder for the Voltmeter, got range 3-30 Volts, 2 wire fit.
The LED in the middle and the strange switch is the manual override for the fan, that one will get an update.
17Back to top Go down   Probs with K75 Empty Re: Probs with K75 Sat Apr 02, 2016 5:07 am
That looks nice, but I must say its ten past one, you sure stay up late Wink
Certainly give us an option when our fails It does look "the go" ace
18Back to top Go down   Probs with K75 Empty Re: Probs with K75 Sat Apr 02, 2016 5:12 am
I live on the other side ofthe world, the Netherlands Wink
You read in local time.
It's now 10:30 AM now here, saturday.
19Back to top Go down   Probs with K75 Empty Re: Probs with K75 Sat Apr 02, 2016 5:30 am
Pics from minutes ago;
Probs with K75 12916104_1163880056969632_8984371472526504141_o
Had the new battery charged, looks like the bugger is smiling to me Smile
Probs with K75 12671987_1163880063636298_1949888909401854332_o
The headlight of the S is the same (ordernr) as the early F650. Mine came from America, has no lightswitch=lights always on. The BMW-joke; take that switch + his loom out, replace 1 on 1 with loom+lightswitch, and it works, it's plug-and-play Smile
Even my Yamaha Diversion (Seca) 600 has the Voltmeter;
Probs with K75 12901378_1163880080302963_1006144192436258570_o
20Back to top Go down   Probs with K75 Empty Re: Probs with K75 Sat Apr 02, 2016 5:47 am
the ten past one comment was due to the 11.0 volts showing on the clock, its ok I thought it was funny,
13.1 volts showing now is much improved, full charge is a good thing
21Back to top Go down   Probs with K75 Empty Re: Probs with K75 Sat Apr 02, 2016 6:00 am
Very Happy Missed that one, but now I get it Very Happy
The 11 Volts was with new batt last year, after lots of fail starts, by then it was still good.
Have been sitting for a year, and died Sad
The Yam, even on 10.5 Volts, it starts!
Not to bug you all, bought the Yam as cheapo to ride till the K is running again.
And the credits, the Yam never failed....
22Back to top Go down   Probs with K75 Empty Re: Probs with K75 Sat Apr 02, 2016 6:29 am
Yes I read of a study here on Australia where they found the Yamaha's were the most reliable of bikes.
Don't know by how much they were ahead of us though, cheers
23Back to top Go down   Probs with K75 Empty Re: Probs with K75 Sat Apr 02, 2016 12:36 pm
Picked up my stock, let the wrench-party begin Probs with K75 167893
24Back to top Go down   Probs with K75 Empty Re: Probs with K75 Sun Apr 03, 2016 9:49 am
The big checkup; all electrics are functioning.
Even the instrument cluster is working, altough it has seen water, and some parts came off Sad
Will replace the cluster, got a spare, with a working clock Smile
25Back to top Go down   Probs with K75 Empty Re: Probs with K75 Fri Apr 08, 2016 12:39 pm
Alive and running Smile
The next problems; Tank is leaking, left side.
And think 1 hall-sensor is bad. Cold ok, warm not ok.
Lucky me got spare parts Smile
26Back to top Go down   Probs with K75 Empty Re: Probs with K75 Fri Apr 08, 2016 7:40 pm
Spares do come in handy, a bummer with the tank leak, have you got a spare Very Happy
27Back to top Go down   Probs with K75 Empty Re: Probs with K75 Mon Apr 11, 2016 4:28 pm
Today exchanged the HESplate and the tank.
Still running on too much fuel Sad
Gonna replace the PR soon, got the old one from an old K75, but works well.
21:25 here, end of day, time to relax Smile
28Back to top Go down   Probs with K75 Empty Re: Probs with K75 Mon Apr 18, 2016 6:12 pm
Ran out of time to proceed, continue later....
29Back to top Go down   Probs with K75 Empty Re: Probs with K75 Sat Aug 06, 2016 2:57 pm
halflive
halflive
I've bought the bugger from Wheeldigger. Pity the pictures are gone but this topic helps me to understand the way Wheeldigger was thinking and what he has exchanged.
For a start i'm gonna try the bike on a new proven Jetronic.
I'm gonna exhange the Airflow sensor as well with one I know is working OK.
I've tested the pressure regulator, it opens between 2,5 and 3 bar. Next step is the temp sensor and pin 10. I know Wheeldigger has installed a new sensor and a replacement loom, but I can not take anything for granted, have to check all te options. If the problem was obvious Wheeldigger would have found it in the first try..... I will put a soldering iron between the sensor and the camchain cover, if everything works the resistance should drop.
Next, somewhere later this week I will check the valve timing and ignition timing.
It must be something simple. Something is telling the Jetronic is is freezing or there are massive amounts of air coming in. Twisted Evil
http://halflive.hostei.com
30Back to top Go down   Probs with K75 Empty Re: Probs with K75 Sat Aug 06, 2016 6:08 pm
Ah, there you are Smile
Welcome to the best K-forum in the world Smile
Still have Red Sonja, the K1100RS/LT Smile
And Nicole von Bayern has arrived, the R1200RT.
She's a K26, they can't kick me out Razz
31Back to top Go down   Probs with K75 Empty Re: Probs with K75 Sat Aug 06, 2016 6:29 pm
The red K75S is Lucille, from the song from Normaal Wink    (Normaal = a Dutch rock & Roll band)
32Back to top Go down   Probs with K75 Empty Re: Probs with K75 Sun Aug 07, 2016 8:45 am
halflive
halflive
Sorry, I don't name bikes, t is just the red K75. The only names I give to bikes are commonly associated with some kind of illness.
33Back to top Go down   Probs with K75 Empty Re: Probs with K75 Sun Aug 07, 2016 10:01 am
halflive
halflive
Holister wrote:Actually, Zero equals CLOSED circuit indicating continuity
I can't reproduce what Wheeldigger was measuring.
I'm very much an electrics dombo, but I think I can grasp this.
Scale to 2000Ohm. Two pins in the air and the display shows 1
Pin on the engine/ground other pin in 10 of multiplug, the display shows 1
Pin on the engine/ground other pin in some random other pins of the multiplug, measuring resistance.
Pin on the engine/ground other pin somewhere else on a bolt/casting, measuring a low resistance about 0.05.
Probs with K75 06_pinnen
To me that sounds as no connection between the temp switch and pin 10.
Next steps: am I measuring between the right points? Where is the open connection?
34Back to top Go down   Probs with K75 Empty Re: Probs with K75 Sun Aug 07, 2016 10:22 am
Next step would be to disconnect the temp sensor, and measure between pin 10 and the sensor connector (the other connector of the two goes to the fan relay).
If still no conductivity, the problem is in the wiring.
If you have conductivity, the problem is the sensor itself or corrosion in the threads.
35Back to top Go down   Probs with K75 Empty Re: Probs with K75 Sun Aug 07, 2016 11:20 am
halflive
halflive
That's my thought also Inge.
I've disconnected the plug at the sensor side. It contains two purple/green wires. One has continuity to pin 10, the other one is open. I presume the other one is to the fan/lamp switch. As long as pin 10 gets ground it should be OK.
Measuring the sensor is very hard, it is almost unreachable. Sometimes I get a flash of resistance on one of the pins, but most of the time not. I will find a suitable container and drain the cooling system, remove the radiator and proceed.
@Wheeldigger, did  you install a brand new sensor or a used one? You did not install it using Teflon tape did you?
36Back to top Go down   Probs with K75 Empty Re: Probs with K75 Sun Aug 07, 2016 8:39 pm
This k got a new sensor, about 3 years ago.
Nope, no teflontape involved Smile
37Back to top Go down   Probs with K75 Empty Solution Tue Aug 09, 2016 10:01 am
halflive
halflive
I think I found the problem. After all a malfunctioning Temp switch
After removal of the fairing and the radiator removing the temp switch was peanuts. One pin of the switch made connection to the housing, Sorry I didn't record the values. The other one didn't. There was no connection between the two pins.
Remember, the wiring was fine. Connecting the wiring and measuring between pin 10 and the switch housing showed there was an open connection.
So I pulled an other switch from an engine wich was running fine. Both pins had a high resistance towards the housing. I boiled some water, poured it in a mug, connected the "new" switch to the wiring and dropped it in the water. Indeed, the resistance on pin ten dropped gradually.
So I fitted the "new" switch connected the rest of the wiring dropped in a battery and started the engine. No black clouds, good gas response, I think I solved it. cheers
I think the first temp switch was defect, or the wrong kind. There are similar looking switches, but working differently. Most of them variate the resistance between the two pins.
@Wheeldigger, do you want the temp switch back to throw it through someones front window? Evil or Very Mad
Off course the bike is running, but not 100%, there is more work to do. Somehow it runs high idle, Adjusting the idle at normal values works fine. but after a minute or five the revs suddenly drop and the engine stalls. Restarting the engine is no problem and the idle is normal again.
I suspect it is in the fuel pressure system, but still have to make a test run to see what the current status of the complaints is.
38Back to top Go down   Probs with K75 Empty Re: Probs with K75 Tue Aug 09, 2016 2:47 pm
Happy you found it Smile
Can throw away the old sensor, be careful with your window Very Happy
Did I leave fuel in the tank?
Better replace all the fuel, our crappy fuel can't last 3 months....
Got that shit in the K1100 Sad
