1Back to top Go down   Stuck drive shaft  Empty Stuck drive shaft on Wed Mar 30, 2016 10:36 pm
mikerogers74
mikerogers74
Hey Guys,
So I've managed to pull the final drive and swing arm off but my drive shaft is pretty stuck. Videos I've seen on you tube show it coming off easily but not so for me. Is the some trick? Hit it with a hammer? Swear at it?
Stuck drive shaft  Img_2310
2Back to top Go down   Stuck drive shaft  Empty Re: Stuck drive shaft on Wed Mar 30, 2016 10:57 pm
Grab it with vice grips on the end and hit it back with a hammer. Just be careful how you let the shaft angle down like you have it. It could damage the uni joint. Give it some support while you remove it.
  Stuck drive shaft  Austra12    Fuel:  95 Octane
3Back to top Go down   Stuck drive shaft  Empty Stuck drive shaf on Wed Mar 30, 2016 11:01 pm
I put a strip of wet n dry 320 grit paper, grit on metal and gripped with locking pliers then whacked, er, gently tapped the pliers with a rubber hammer, backwards that is.
4Back to top Go down   Stuck drive shaft  Empty Re: Stuck drive shaft on Wed Mar 30, 2016 11:06 pm
mikerogers74
mikerogers74
Sounds good. So basic approach is:
Stuck drive shaft  Milwau10
Stuck drive shaft  Thor10
5Back to top Go down   Stuck drive shaft  Empty Re: Stuck drive shaft on Wed Mar 30, 2016 11:14 pm
Laughing ya got the basic idea.... just wind it down a little. Laughing Laughing
Stuck drive shaft  16
6Back to top Go down   Stuck drive shaft  Empty Re: Stuck drive shaft on Wed Mar 30, 2016 11:15 pm
If you need to do something and there is a big guy standing around in a red cape, do what he would do...
7Back to top Go down   Stuck drive shaft  Empty Re: Stuck drive shaft on Wed Mar 30, 2016 11:30 pm
I found the first time that I took the shaft out of my K75 (swingarm was still on) I was not having much success with the aforementioned method ............. until I put a piece of soft wood  at the rear end of the shaft and gave it a firm hit (just one) forwards, then the next tap on the pliers towards the rear freed it.
Good luck.
8Back to top Go down   Stuck drive shaft  Empty Re: Stuck drive shaft on Wed Mar 30, 2016 11:32 pm
mikerogers74
mikerogers74
thanks guys, will have a shot at it tonight and report the progress/breakages.
9Back to top Go down   Stuck drive shaft  Empty Re: Stuck drive shaft on Wed Mar 30, 2016 11:54 pm
One thing I didn't see mentioned above.  When you have the vise grips on the end of the shaft make sure the shaft is as closely in line with the output splines on the transmission when you whack the vise grips.
10Back to top Go down   Stuck drive shaft  Empty Re: Stuck drive shaft on Thu Mar 31, 2016 7:00 am
My slightly less kinetic method (worked for me several times without issue) is to put a crowbar/pinchbar/jemmy/insert-local-variation-of-the-tool-here against the front side of the universal joint. Hold onto the drive shaft and gently apply effort to the crowbar (push the free end of the crowbar gently forward using the gearbox casing as the fulcrum) and the shaft just very easily pops out. No vice grip marks on the shaft, no mashed fingers from missed hammer blow and practically no effort at all. A lot less chance of damage IMHO. If you want to be a purist, then put some soft wood/cardboard packing between the crowbar and the universal joint and between the crowbar and the gearbox casing to avoid marking it - but in my experience, this has not been an issue.
Good luck
Stuck drive shaft  Uk-log10 Stuck drive shaft  Sco-lo15Stuck drive shaft  Eu-log10
                              Paul  Stuck drive shaft  905546712
11Back to top Go down   Stuck drive shaft  Empty Re: Stuck drive shaft on Thu Mar 31, 2016 7:07 am
+1 on the above. Any sort of hit with a hammer or such you risk bruising the case hardening on the Uni joint and failure down the line.
12Back to top Go down   Stuck drive shaft  Empty Re: Stuck drive shaft on Thu Mar 31, 2016 7:25 am
Of course, to use my method, you need to remove the swing arm so you can access the universal joint...
Worth doing anyway if only to clean up the bearings and check the gaitors and get to the GPI switch (while you're in there).
13Back to top Go down   Stuck drive shaft  Empty Re: Stuck drive shaft on Fri Apr 01, 2016 8:39 am
I'm with BAE and Rick. Spending a couple of minutes (if that) taking the swingarm off allows you to do any needed maintenance on the pivots too. Or, in my case on LFB, cussing and heaving for half-an-hour trying to break the corrosion seal on the right-hand pivot with an eighteen-inch water pipe wrench. I got there... eventually. The pivot still has the battle scars. Very Happy Very Happy
14Back to top Go down   Stuck drive shaft  Empty Re: Stuck drive shaft on Fri Apr 01, 2016 3:41 pm
@Dai wrote:...in my case on LFB, cussing and heaving for half-an-hour trying to break the corrosion seal on the right-hand pivot with an eighteen-inch water pipe wrench...
That was my first experience of getting the critter out too, Dai.
I've not had a problem since, hence the benefit of applying a little extra effort and taking the swing arm off and then spending a few minutes cleaning things up and adding a little smear of grease where needed. A few minutes "while you're in there" can pay big dividends later on, especially if that 18" wrench is not conveniently to hand. It is also refreshingly pleasing when doing the job the next time and the pivot just slides smoothly out, leaving you feeling all smug and self contented with yourself (or the caring PO - thanks Stephen)!!
