1Back to top Go down   Mystery tube Empty Mystery tube on Thu Mar 31, 2016 5:34 pm
Bikesmith
Bikesmith
Hey guys,
    What is this little tube coming out of the transmission of my 85 K100rs right under the battery shelf?
Mystery tube Tube
Jon
Mechanically competent, electrically idiotic
1985 BMW K100rs
1940 Royal Enfield WD/CO
1968 Honda CL125
2Back to top Go down   Mystery tube Empty Re: Mystery tube on Thu Mar 31, 2016 5:42 pm
Battery breather.
3Back to top Go down   Mystery tube Empty Re: Mystery tube on Thu Mar 31, 2016 5:54 pm
Bikesmith
Bikesmith
So, where should that loose end be plugged into? Into the battery? My battery doesn't have a hole for it. Should I leave it loose?
Jon
1985 BMW K100rs
1968 Honda CL125
4Back to top Go down   Mystery tube Empty Re: Mystery tube on Thu Mar 31, 2016 6:07 pm
Chocolate
Chocolate
A modern AGM or Gel Batterie will not need this tube.
A old acid Battery will net this tube, when it heats up it will evaporate water and a bid acid.
If the tube isn't connected or plugged with dirt, the acid will drop on the frame and destroy the frame coat.
I had that, looks ugly!
Mystery tube 0010e
5Back to top Go down   Mystery tube Empty Re: Mystery tube on Thu Mar 31, 2016 9:11 pm
Onya Choco, in some cases photos are the only way to go!
