1Back to top Go down   Thickest valve shim? Empty Thickest valve shim? on Sun May 01, 2016 9:46 pm
feo
feo
Long story made short-
I've got 3 tight exhaust valves, all at .20mm.
The shims weren't marked, when I measured with my micrometer, #3 cyl has a .132 inch shim. That works out to 3.35mm and change.
Thickest shim on the innerwebs I've found is 3.10mm
Don't think I want to try running .45mm lash.
Got something else to try, but in the meantime, What's the thickest shim anyone has seen in a K-bike engine?
2Back to top Go down   Thickest valve shim? Empty Re: Thickest valve shim? on Sun May 01, 2016 10:06 pm
The thickist 29mm shim I have ever seen is a 3.20mm. Not sure if BMW has a 3.20 but Kawasaki has that size in a 29mm shim.
3Back to top Go down   Thickest valve shim? Empty For 16V they are 2.50mm through on Sun May 01, 2016 11:35 pm
For 8V K100 (& all K75) they are available in 2.0mm through 3.0mm sizes. For 16V they are 2.50mm through 3.20mm.
It's always a good idea to have your bike's year & model specifics in your signature so the question can be answered with some accuracy.
1977 R75/7-R100 grey, '87 K100RS red, '93 K11-K12 aka 'Big Block' black, '96 K1100RS black, '98 K1200RS red, '09 K1300GT red, & 2013 R1200RT-Polizia black & white.
4Back to top Go down   Thickest valve shim? Empty Re: Thickest valve shim? on Mon May 02, 2016 12:10 am
feo
feo
Sorry about that, overlooked that.
1990 K75RT, 65,000 miles on odometer (if it can be believed, LOL)
Since I pulled the camshaft, I also got to check differences in the shim buckets. I may have a solution with that.
Has anyone swapped buckets between bores on purpose? Not just absent-mindedly.
Would an exhaust clearance of .33mm-.35mm be a major problem?
5Back to top Go down   Thickest valve shim? Empty Re: Thickest valve shim? on Mon May 02, 2016 12:34 am
You gotta ask yourself why it needs a thick shim like that to begin with. I'd say at 3.35mm it's out of spec. The thickest shim Motorworks sell is 3.00mm.
Possibly the end of the valve stem is worn??
What do the other shims measure?
Are the old shims dished? You need to measure in the middle of the shim.
The place I buy my shims from in Melbourne AU have 29mm flat shims from 1.40 thru to 4.50 in 0.05mm increments @ AU$10 each.
  Thickest valve shim? Austra12    Fuel:  95 Octane
6Back to top Go down   Thickest valve shim? Empty Re: Thickest valve shim? on Mon May 02, 2016 12:51 am
feo
feo
I'm a bit confused by it, I don't remember ever dealing with a shim thicker than 3.00mm on Kawasakis when I worked on them (back when K-bikes were new on the market).
End of the valve stem looks good and feels good. I'm not willing to pull the head at this point to investigate root causes. Yet.  Laughing
The other shims were 2.85 and 2.8, I've got proper size replacements for them in my parts stash (KLR650 leftovers).
I'm gonna take a brand-new 2.60 Kawasaki shim and use it to compare bucket-to-bucket differences in the morning before work.
I'll try to report back tomorrow night.
1990 K75RT, more before it, more to come. GF's 1991 K75RT will be my maintenance job for a long time to come.
7Back to top Go down   Thickest valve shim? Empty Re: Thickest valve shim? on Mon May 02, 2016 1:11 am
@feo wrote:I'm a bit confused by it, I don't remember ever dealing with a shim thicker than 3.00mm on Kawasakis when I worked on them (back when K-bikes were new on the market).
I don't think you'd actuall 'see' the wear on a valve stem end. You'd have to measure it.
How about the buckets? any wear there?
2.80 & 2.85 sounds a little thick also but the fact that one is hugely different at 3.35 may indicate there's a problem.
All my exhaust shims are around the same at an average of 2.50mm
8Back to top Go down   Thickest valve shim? Empty Re: Thickest valve shim? on Mon May 02, 2016 2:59 am
unless someone did some work to the head and recut the valve seats ...and reground the valves .....then cut too much off the valve length to compensate ?
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%OThickest valve shim? Au-log10
9Back to top Go down   Thickest valve shim? Empty Re: Thickest valve shim? on Mon May 02, 2016 4:10 am
Snod Blatter
Snod Blatter
Kaptain Holister wrote:2.80 & 2.85 sounds a little thick also but the fact that one is hugely different at 3.35 may indicate there's a problem.
Yeah, this! I've just replaced three shims, two exhausts and one inlet, and they were all 2.5mm and I've replaced them all with 2.45mm. This is totally normal, as I'm sure you know.
With shims so thick do they sit proud of the bucket? Perhaps the cam is no longer straight? All very strange!
Others: 1.5 x Honda CBX250RS-E, '94 CB250, '95 TRX850, '16 Z250SL
10Back to top Go down   Thickest valve shim? Empty Re: Thickest valve shim? on Mon May 02, 2016 10:27 am
feo
feo
Well, it's amazing what a night's sleep and no home improvement projects can do.
Like reading a micrometer right.
Grrrrrrr.
It was .1032, NOT .132.
I unpacked a new 2.60 Kawasaki shim, and as soon as I had it in hand and felt it, I knew I'd screwed up.
The actual shims were 2.55, 2.55 and 2.60.
They've been replaced with 2.45, 2.45 and 2.50, I now have .30mm clearance on all exhausts.
I really am one of those people that function best mentally in the mornings.
Shocked
11Back to top Go down   Thickest valve shim? Empty Re: Thickest valve shim? on Mon May 02, 2016 6:59 pm
Good to hear it's sorted and it didn't turn into a major repair. Often its the simplest thing.
