1Back to top Go down    K1100RS wheel bearing installation on Thu May 19, 2016 12:41 am
My new (to me) K1100RS has been pulling to the right badly. I suspected something in the front end. Found the right wheel bearing is totally shot.
Have been able to identify the required bearings
Left - 25x47x12 - 6005RSR
Right - 25 x 52 x 20.6 - 3205-2RS
Can anyone tell me what the installation procedure is. Or give me a link.
I'm on the road in Perth WA and need to get going asap.
1988 K100RT VIN No. 0094680
1989 K100RT VIN No. 0097367 (naked)
1996 K1100RS VIN No. 0451808
Fuel: 95 Octane
Engine Oil:Nulon Full Synthetic 15W50
Gear Box Oil: Nulon Synthetic 75W90
2Back to top Go down    Re: K1100RS wheel bearing installation on Thu May 19, 2016 2:17 am
I presume the wheel is out but if not it'd done in a similar way to a K100 except the calipers have to come off.
There is a big circlip which has to come out then the bearings knock out and the hotter the wheel the better.
You need to get some room on the first bearing by puting a large screwdriver in through the first bearing but not to the second and heave on it to crush the thin steel collar that holds the sleeve concentric then you can get a drift at the bearing. When you are reinstalling the bearings DONT tap on the inner race just the outer and all will go together well. Probably take an hour or so. Don't forget ti straighten the collar or it's difficult to get the axle back through.
Be prepared the double row race is around $50 the other $20'.
Best of luck and it's good to discover that now and not at Madura or thereabouts.
"Every normal man must be tempted, at times, to spit upon his hands, hoist the black flag, and begin slitting throats." from Mencken's 1919 Prejudices
3Back to top Go down    Re: K1100RS wheel bearing installation on Thu May 19, 2016 2:27 am
Thanks Rick. Just picked up bearings in Bunbury. Cost $54 for both so not so bad.
Yes. Lucky I think, to have found that now before I left.
Fuel: 95 Octane
4Back to top Go down    Re: K1100RS wheel bearing installation on Thu May 19, 2016 4:46 am
All went well. New bearings in place.
Just doing the fork oil now (350ml left. 400ml right??) and I should be good to go.
Fuel: 95 Octane
5Back to top Go down    Re: K1100RS wheel bearing installation on Thu May 19, 2016 5:56 am
Chocolate
Fork Oil Quantities/Capacities
Model Leg Change Disassemble
K75 Showa L 410 cc 420 cc
K75 Showa R 410 cc 420 cc
K75 BMW L 330 cc
K75 BMW R 330 cc
K75 Sport L 280 cc
K75 Sport R 280 cc
(Has an "S"stamped on the aluminium plug on top of the leg.)
*16V*
K1100LT L 350 cc 400 cc
K1100LT R 400 cc 400 cc
K1100RS L 350 cc 400 cc
K1100RS R 400 cc 400 cc
K1, K100RS L 380 cc 400 cc
K1, K100RS R 380 cc 400 cc
K-bike fork oil requirements
Front Fluid Quantity and Suspension Response
6Back to top Go down    Re: K1100RS wheel bearing installation on Thu May 19, 2016 9:29 am
Thanks for that Choco. I would have that on my laptop at home but I'm travelling light and have only brought my tablet with me.
Fuel: 95 Octane
