1Back to top Go down   Siezed ABS sensor Empty Siezed ABS sensor Wed May 25, 2016 4:57 pm
Having real trouble getting the ABS sensor out of the fork leg on the K1100rs. The sensor is in poor shape from previous mishandling and so I am regarding it as a gonner and will replace it but right now I just want it out for removing the forsk to do the seals.
Any tips on getting it free without damaging the fork?
Siezed ABS sensor Ir-log1188....May contain nuts!Siezed ABS sensor Ir-log11
K75RTP - 1994
2Back to top Go down   Siezed ABS sensor Empty Re: Siezed ABS sensor Wed May 25, 2016 6:42 pm
BFH used carefully Very Happy
3Back to top Go down   Siezed ABS sensor Empty Re: Siezed ABS sensor Wed May 25, 2016 10:10 pm
Heat with small torch.
Small Vise-Grips.
Or pound a Torx bit into it.
When you put the new one in use anti-seize.
4Back to top Go down   Siezed ABS sensor Empty Re: Siezed ABS sensor Thu May 26, 2016 3:12 am
Unplug it and leave it there. If it doesn't work then use the RBFSH and hit it very gently.
5Back to top Go down   Siezed ABS sensor Empty Re: Siezed ABS sensor Thu May 26, 2016 4:45 am
Hi Will
If all else fails you could always cut the wire, one of my bikes had this done to it by a PO and it was then re-connected
Siezed ABS sensor Ir-log10
   ;BMW; K100RS Style Black 1987 105K Km     ;BMW; K1 Black 1993 60K Km     ;BMW;  K1100RS Black 1996       ;BMW; K1 Blue 1990 25K Miles
