1Back to top Go down   whole system shuts down Empty whole system shuts down Sun Jun 05, 2016 12:18 pm
piseth
piseth
Hi folks, any of you have encounter the following:
I did a 500 km trip ride with my guys. I was on the way back back when suddenly the whole system just shut off by itself. The meter just black out and the bike just shut down. Park by the road side check any possibilty that the cable connected to battery might be loose. Nope found no sign. Then i just turn the key on, everything is back to normal. This sudden shut down is happening everyday since the trip. It will shut down at least 1 time a day. Today my bike started to jerk when on the move and i keep having back blast as its farting all the way non stop. Any idea on this issue? I have just changed the spark plugs before the trip. 1 more issue is when im on high speed around 140km/ph, onwards, the engine is like out of breath when i close throttle. It died on me once. Thanks in advance
2Back to top Go down   whole system shuts down Empty Re: whole system shuts down Sun Jun 05, 2016 1:22 pm
Sounds like a dirty ignition switch.  I had the same problem last year.  Disassembly and cleaning has fixed it.
3Back to top Go down   whole system shuts down Empty Re: whole system shuts down Sun Jun 05, 2016 3:55 pm
I agree with .75. It's the only place in the entire wiring loom that can kill the whole bike.
4Back to top Go down   whole system shuts down Empty Re: whole system shuts down Sun Jun 05, 2016 9:17 pm
Yep + 1 on that.
5Back to top Go down   whole system shuts down Empty Re: whole system shuts down Mon Jun 06, 2016 12:01 am
piseth
piseth
Hi Folks , thanks for the information. Just a silly question,you mean we got to take out the while switch where we put the key in?
Laughing Laughing Laughing
K100 RS 1990 December
Last Location: Japan
Current Location: Cambodia
vin:0201460
6Back to top Go down   whole system shuts down Empty Re: whole system shuts down Mon Jun 06, 2016 1:22 am
Rickmeister
Rickmeister
Yep! Happened to me last year...oliver sudden the thing just stops at the most in-opportune moment. Remove the ignition switch...it comes in two parts...the key part and the switch part (from memory!?) The switch part is relatively easy to pull apart and clean the contacts. Good luck!
7Back to top Go down   whole system shuts down Empty Re: whole system shuts down Mon Jun 06, 2016 6:45 am
Ajays posted a write-up on cleaning the ignition switch here:
http://www.4shared.com/account/dir/32417964/fca60d54/sharing.html?rnd=88
You need some form of 'social media' account to download it (farcebook etc.).
8Back to top Go down   whole system shuts down Empty Re: whole system shuts down Mon Jun 06, 2016 7:10 am
piseth
piseth
Thanks folks. Really great help. Will try to bring my bike out to shop i dont have any tools for my bike. Will post the result after its done. Cheers folks
vin:0201460
9Back to top Go down   whole system shuts down Empty Re: whole system shuts down Thu Jun 09, 2016 10:23 am
piseth
piseth
Solved 1 problem. Bike jerk and keep back blasting. Cause by spark plug cable cab that dropped out of its place as it was not inserted properly after change of new set of plugs. As for the ignition switch, i could not remove the lower part so i sprayed some cleaner in. So far so good.
vin:0201460
10Back to top Go down   whole system shuts down Empty Re: whole system shuts down Thu Jun 09, 2016 10:50 am
The top part of the switch is just the lock mechanism and is totally separate to the switch below it except for a tang which turns the switch. Spray lube in the lock will not get to the switch
There's a small screw on the side which when removed allows the switch to come away from the bottom of the housing.
Try these instructions for cleaning the switch
Here's some aditional tips and pics
 whole system shuts down Austra12    Fuel:  95 Octane
11Back to top Go down   whole system shuts down Empty Re: whole system shuts down Fri Jun 10, 2016 1:58 am
piseth
piseth
vin:0201460
12Back to top Go down   whole system shuts down Empty Re: whole system shuts down Fri Jun 10, 2016 2:01 am
piseth
piseth
Holister wrote:The top part of the switch is just the lock mechanism and is totally separate to the switch below it except for a tang which turns the switch. Spray lube in the lock will not get to the switch
Hahaha i could not get the screw out. Spray the lube in at the bottom. Figuring it for half a day. Will try to do it again. Thanks.
vin:0201460
