1Back to top Go down   Hello from Darwin Empty Hello from Darwin on Thu Jun 30, 2016 4:12 pm
schmik
schmik
Hi there everyone. There is a lot of such valuable information here!
A friend has bought a brick and as his background is in MX, wants to put some big handle bar raisers and turn it into what would best be described as within the scrambler genre.
I was suggesting that he install the BEP2.0 from maru-labs for simplicity.
He is looking for two x 2-1 exhaust joints and aiming for a dual muffler system up the left read of the bike.
Everything else will be simple and neat.
Any early advice will be helpful and thanks for all the information given here so far!
Michael
2Back to top Go down   Hello from Darwin Empty Re: Hello from Darwin on Fri Jul 01, 2016 3:07 am
Hello from Darwin 177912 I'm not sure if anyone has done a 4-into-2 system but it should be possible.
3Back to top Go down   Hello from Darwin Empty Re: Hello from Darwin on Fri Jul 01, 2016 2:38 pm
G'day Michael and welcome to the forum.
"I'm not sure if anyone has done a 4-into-2 system but it should be possible."
Here's one that was prepared earlier...
Hello from Darwin K100_t10
4Back to top Go down   Hello from Darwin Empty Re: Hello from Darwin on Fri Jul 01, 2016 5:41 pm
welcome Michael
a bit of welding and some pipe bending should get you going ...but the sizes are a little small for normal stuff at 28mm (round abouts )
34 od mm should be found easier
good luck with it ...and keep us posted to the outcome
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%OHello from Darwin Au-log10
5Back to top Go down   Hello from Darwin Empty Re: Hello from Darwin on Fri Jul 01, 2016 6:40 pm
@blaKey wrote:G'day Michael and welcome to the forum.
Does look good with 2 pipes......
1997 K1100LT 0188024 Wotan Mystic Red 689 58,645 now 100,380 miles
1983 K100RS 0011171 Fricka 606 29,495 miles Damn K Pox Its a Bat outta Hell No 33,600 miles
