1Back to top Go down   Trailer suspension modification Empty Trailer suspension modification on Tue Jul 05, 2016 9:11 pm
Garyk100
Garyk100
:-c: In this post I will endeavour to modify the suspension on a 2004 classic industries ultra lite trailer, I will be changing from the standard rubber block alco suspension to an axle with leaf springs, any info or help will be really really welcome. Pics details swearing and cursing to come,
The early bird catches the worm, but the second mouse gets the cheese
1991 K100rs16v
1993 K1100LT
2Back to top Go down   Trailer suspension modification Empty Re: Trailer suspension modification on Tue Jul 05, 2016 9:41 pm
Active Fabrications is where I get my gear for trailers http://www.activefabrications.com.au/
It may be a fair way south but it is worth the trip.
3Back to top Go down   Trailer suspension modification Empty Re: Trailer suspension modification on Tue Jul 05, 2016 9:55 pm
Garyk100
Garyk100
That looks a good place to get parts Rick, we have a few trailer manufacturers here in Redcliffe, round axle or square, eye to eye or slipper springs ?
1991 K100rs16v
1993 K1100LT
4Back to top Go down   Trailer suspension modification Empty Re: Trailer suspension modification on Wed Jul 06, 2016 3:00 am
Slipper springs, eye to eye make it much higher and an axle 39mm round is quite strong enough.
If you have access to a lathe I will send you drawings on how to make a pipe axle that is heaps strong enough but dont just weld right around the stub where it goes into the pipe or it will just tear out and the wheel falls off.
Before you get the axle made measure the wheel from inside to the flange and the width of the body at widest point which will be at the rear most of the wheel arch on a classic.
If you want drawings on shock mounts give me a yell
5Back to top Go down   Trailer suspension modification Empty Re: Trailer suspension modification on Sun Jul 24, 2016 8:46 am
Garyk100
Garyk100
Oops trailer sold due to a change in the weather and the tide came in twice yesterday , should I delete this post or maybe some one may take it over ? Yes I live near the beach and counted the tide.ShockedVery Happy
1991 K100rs16v
1993 K1100LT
6Back to top Go down   Trailer suspension modification Empty Re: Trailer suspension modification on Sun Jul 24, 2016 11:20 am
Leave it up mate someone will benefit from out ramblings and I may take some photos to up date it as I do the mods on the trailer.
7Back to top Go down   Trailer suspension modification Empty Struts on Mon Jul 25, 2016 10:57 am
Garyk100
Garyk100
The struts in the trailer are cactus as Rick know, here is a link to work out what psi is needed if anyone may need it
http://www.gasstrutaustralia.com.au/gas-struts-australia-help-with-gas-struts/gas-strut-calculation
1991 K100rs16v
1993 K1100LT
