1Back to top Go down   starting problems help! Empty starting problems help! on Sat Jul 09, 2016 6:25 pm
Ken52
Ken52
Please help having issues with my K100RT,
I have replaced the battery and the starter and starter relay.
Bike will not start at all just makes a buzzing sound in electrics box. the battery is new and fully charged the relay is new and starter too.I don't know where to look now can you please help? I would appreciate it very much. Crying or Very sad Crying or Very sad
2Back to top Go down   starting problems help! Empty Re: starting problems help! on Sat Jul 09, 2016 6:43 pm
A useful guide is linked in the Portal page of this forum:
http://hrsbstaff.ednet.ns.ca/bvogel/K100/download/bike-wont-start.htm
Go through this document to try and isolate your problem.
Has this motorcycle suddenly stopped working? Is it new to you and you've never had / seen it running?
3Back to top Go down   starting problems help! Empty still bad on Sat Jul 09, 2016 10:57 pm
Ken52
Ken52
@Ken52 wrote:Please help having issues with my K100RT,
Put in the relay still nostarting ,took battery out battery shows its shot. don't know what happened hasn't started since replaced  starter.or relay,same symptoms, bike was running up till two weeks ago relay just chatters.
4Back to top Go down   starting problems help! Empty Re: starting problems help! on Sun Jul 10, 2016 12:08 am
The chattering is very indicative of a shot battery. I would suggest charging for a full 10 hours then try if it fails take the battery back and get it load tested. It wouldn't be the first time I have seen a crap, new battery.
5Back to top Go down   starting problems help! Empty Re: starting problems help! on Sun Jul 10, 2016 7:23 am
What Rick says - all of it.
6Back to top Go down   starting problems help! Empty Re: starting problems help! on Sun Jul 10, 2016 8:27 am
before you do anything ...make sure that the earth cable to the gearbox is good
high resistance here could do exactly that ...no function on start ..eratic relay clicking and all that stuff ...
many have replaced the earth cable for something better
just a heads up
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%Ostarting problems help! Au-log10
7Back to top Go down   starting problems help! Empty same issue on Sun Jul 10, 2016 10:40 am
Ken52
Ken52
Thankyou gentleman had battery retested (it's toast) will be replacing Monday will let you know...thanks
