1Back to top Go down    Acewell fuel gauge fix? Empty Acewell fuel gauge fix? on Thu Aug 04, 2016 5:06 pm
Neil_art
Neil_art
for all of you with Acewell gauges, I've manage to get the fuel gauge to kinda work, not sure how accurate it is but is seem to work, all I did was attach the yellow wire from the additional gauge connector (that might not be what it's technically called) under the tank to the dark blue wire on the Acewell, my bike is a K75c 1986 so could work for you  Acewell fuel gauge fix? Icon_smile
 Acewell fuel gauge fix? Petrol11
2Back to top Go down    Acewell fuel gauge fix? Empty Re: Acewell fuel gauge fix? on Thu Aug 04, 2016 5:26 pm
Chocolate
Chocolate
Hey!
Thanks for sharing.
3Back to top Go down    Acewell fuel gauge fix? Empty Re: Acewell fuel gauge fix? on Thu Aug 04, 2016 6:32 pm
It's going to indicate fuel level in reverse. The Acewell expects high resistance for full tank and low for empty. K-bikes indicate the opposite. You'll have to do the modification I outline in my post on Messing with the In-tank Fuel Sender.
4Back to top Go down    Acewell fuel gauge fix? Empty just got lucky? on Thu Aug 04, 2016 6:55 pm
Neil_art
Neil_art
Hi Rob, I've done no modification and it seems to work, when low is shows one bar and full nearly all the bars as per the picture just under three quarters full, maybe i just got lucky?
5Back to top Go down    Acewell fuel gauge fix? Empty Acewell expertise needed on Fri Mar 31, 2017 6:24 pm
FreyZI
FreyZI
So, after a lot of fiddling around, I FINALLY got SOME things working with the new Acewell 6653 gauges.  Among other things, the LED turn signals are all working (with the aid of resistors) and flashing well within the 200 per minute maximum in Pennsylvania.
For those of you who have an Acewell unit, here's the question:  When the signals blink, does the backlighting on the gauge blink, too?  I can't see any reason for that to happen, other than the dummy light.
Assuming that should not happen, any suggestions for remedying the problem?
Cheers,
Frey
PS, nothing was working with the battery tender on.  Guess that may be obvious to some of you with more electrical knowledge.
6Back to top Go down    Acewell fuel gauge fix? Empty Re: Acewell fuel gauge fix? on Fri Mar 31, 2017 9:33 pm
perhaps just flood of the indicator lamps ? when active ?
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%O Acewell fuel gauge fix? Au-log10
7Back to top Go down    Acewell fuel gauge fix? Empty Scheisse on Fri Mar 31, 2017 10:50 pm
FreyZI
FreyZI
So, I went and had dinner, came back, tried the indicators again so I could clarify exactly what happens, and totally different presentation.  I touched nothing.
8Back to top Go down    Acewell fuel gauge fix? Empty Re: Acewell fuel gauge fix? on Sat Apr 01, 2017 9:12 am
You have gremlins. Loose wires?? This problem may come back to haunt so go over your wiring again.
9Back to top Go down    Acewell fuel gauge fix? Empty Re: Acewell fuel gauge fix? on Sat Apr 01, 2017 12:11 pm
 Acewell fuel gauge fix? 112350
