1 Forks seals question. Wed Jul 27, 2016 9:52 am
Today I decided to remove the fork on the K100 solo to replace the seals.
I didn't have to remove the fairing (just the front radiator grill in order to slack the bolts on the bottom triple tee).
When the forks were on the bench, it was very easy to get the stancion out. I just removed the screw at the bottom of the slider and the stancion came out very easy.
Now it's time to get new seals but I am in a bind.
As I don't have a BMW dealer close from home, the seals will have to be ordered.
Which ones as BMW had different types of forks over the years?
According to the S/N (0051114) the bike is a 09/1984 K100rt USA and the seal part # would be 31 42 1 450 127
The fork is marked "Brembo 1.450.520" and I took some dimensions:
Stancions diameter: 41.38mm
Bore diameter of the sliders: 50.88mm
Depth of the bore on the sliders: 6.85mm
Does anybody has the same fork and can confirm the part # for the seals?
CF
CF
1986 k75, 1985 K100rt, |
