1Back to top Go down    Speedo cog on Sun Aug 07, 2016 5:01 am
Garyk100
Garyk100
I have looked through the forum for replacing the cog in the speedo, does anyone know if there is a guide of how you disassemble the instruments, to replace the cog, cheers Gary:M:
The early bird catches the worm, but the second mouse gets the cheese
1991 K100rs16v
1993 K1100LT
2Back to top Go down    Re: Speedo cog on Sun Aug 07, 2016 6:58 am
3Back to top Go down    Re: Speedo cog on Sun Aug 07, 2016 7:19 am
Garyk100
Garyk100
Thanks Dai, um still a bit confused they are good exploded diagrams but I am a novice at this dash thing and need some steps as to what has to be removed how when and where, brain must be on holidays, I have the workshop manual and it shows how to totally disassemble and reassemble just not sure if it needs to be pulled to bits or just remove 2 screws and bobs your uncle
1991 K100rs16v
1993 K1100LT
4Back to top Go down    Re: Speedo cog on Sun Aug 07, 2016 5:16 pm
The instrument panel has to come to pieces. If you search on 'cog' in the forum, there's been a few posts on just that problem.
5Back to top Go down    Re: Speedo cog on Sun Aug 07, 2016 7:58 pm
Garyk100
Garyk100
1991 K100rs16v
1993 K1100LT
6Back to top Go down    Speedo cog on Sun Aug 07, 2016 8:01 pm
If you look in the "how To" section of the Forum in downloads, there are 2 detailed posts, one in particular has step by step instructions and photos. I remember the first step after getting the speedo off the frame is removing the little knob that resets the mileage. It just pulls out, has to be done before the case can be opened.
Good luck. (put a big plastic bag over everything, there are springs and small things).
Suzuki V Strom 650DL 2011. Gasp, chain driven.
7Back to top Go down    Re: Speedo cog on Mon Aug 08, 2016 12:21 am
Garyk100
Garyk100
[url=https://servimg.com/view/18791023/89][/url]
[url=https://servimg.com/view/18791023/90][/url]Found the posts Ta,
ok I purchased a K1100 police inst cluster from Floyd, it needs the cog that wears out but the dash is in very very good nick, I knew this when I bought it, very good price.
My speedo stopped working a few months ago which was hard to tell as when the bike is in the sun you can't see much due to the crazing and cracks have not known the time for a few years cause you can't see the clock.
It is the original dash and the bike had a minor accident before I bought it so there are a few scrapes and scratches, the dash has a few deep marks.
So which dash to fix? Or which shiney bits to use.
After my dash was disassembled the choice is easy, I will use the police dash, as mine is a mess, 3 cogs stripped an aftermarket wire with bulb inside the oil light indicator, oh and this wire is not connected to anything on the bike.
1991 K100rs16v
1993 K1100LT
8Back to top Go down    Re: Speedo cog on Mon Aug 08, 2016 2:20 am
Gary, having repaired a few of these things consider the following. The smallest cog can be bought in a cluster packet from Jaycar, about $8 for the lot, but the smallest cog is the only one that can be used. The rest of the cogs are about $25 each plus about the same in postage. Theyall go brittle/melt in time because our climate... if it feels waxy or brittle, replace it. Once all have been replaced they should give you 25/30 years service.
1983 K100basic vin 0003960 colour red
1987 K100RT vin 0094685 colour, orange peel, sorry, pearl
9Back to top Go down    Re: Speedo cog on Mon Aug 08, 2016 3:43 am
Garyk100
Garyk100
Yes the rest of the cogs in the police dash look in good condition and clean, I have ordered the cog from Sydney for $35 inc post.
http://www.repairsonly.com.au/index.html
Now looking at the dash it has less numbers so they are a lot easier to read, sounds good to me.
The police were limited to 220km/h so I could leave them behind cause my speedo says I can do 260km/h.lol!
1991 K100rs16v
1993 K1100LT
10Back to top Go down    Re: Speedo cog on Mon Aug 08, 2016 4:06 am
Garyk100
Garyk100
Just a question to anyone that may have the answer,
I missed taking a photo before I removed the dash,but there was the original connector plug (with silicone on it) and a double wire coming from a hole drilled in the back of the dash, I traced this wire back it goes for about 30cm then stops,no matching plug that I can find.
But when you pull the back of the dash it unplugs the bulb from 2nd spot down from the oilcan on the taco face, as the bulb and wire are short it would be fiddly to put back in.
There are pics above of this bulb and lead.
Anyone know what or why it's been added or will it affect something with the police dash
I think the bike used to have an alarm fitted.
1991 K100rs16v
1993 K1100LT
11Back to top Go down    Re: Speedo cog on Mon Aug 08, 2016 4:40 am
@Garyk100 wrote:The police were limited to 220km/h so I could leave them behind cause my speedo says I can do 260km/h.lol!
Let us know when and where you do it. Very Happy We won't even quibble about indicated vs actual (GPS) speed.
1985 K100RT VIN 0028991 My original Very Happy (Historic rego)
1985 K100RT VIN 0029036 BOB the Blue Old Bike (Historic rego)
1990 K100LT VIN 0190452 Work in progress
1984 K100RT VIN 0023022 Work needing lots of progress
1986 K100RT VIN 0090542 Work needing lots and lots of progress
1993 K1100LT VIN 0183046 Work in progress
1993 K75S VIN 0213045 Newest toy, slightly non-original
12Back to top Go down    Re: Speedo cog on Mon Aug 08, 2016 7:45 am
Two choices with the flying bulb:
1. It was part of the alarm system
2. Someone tried to reinstate the fast idle warning light that was deleted from the later models.
My guess is (1), but either way, it isn't needed.
13Back to top Go down    Aaaah on Mon Aug 08, 2016 7:54 pm
Garyk100
Garyk100
Ok been trying for a week to get the part from Richard in Sydney. Rang 4 times sent 3 emails and he is now in hospital his mum says, probably true, can some tell me where I can get the cog from. Gary
1991 K100rs16v
1993 K1100LT
14Back to top Go down    Re: Speedo cog on Mon Aug 08, 2016 11:23 pm
I suppose you could get it fromthe US..via the link from Richard's website or maybe try Otto Instruments in Brisbane. Last time I had dealings with them they wanted all theinstruments together back in the case and sent to them.
15Back to top Go down    Re: Speedo cog on Mon Aug 08, 2016 11:32 pm
Garyk100
Garyk100
Thanks ainsjac
Yes tryed otto "he only repairs" found this on a BMW e30 forum, they are located on the Southside of Brisbane. They knew of the cog and were out of stock but I will have it here in few days I think it was $36 delivered.
http://www.ableinstrument.com/
1991 K100rs16v
1993 K1100LT
16Back to top Go down    Re: Speedo cog on Tue Aug 09, 2016 12:33 am
Thats an improvement, last time I spoke with Lionel Otto he was refusing to fix K instruments he must have relented under pressure.
"Every normal man must be tempted, at times, to spit upon his hands, hoist the black flag, and begin slitting throats." from Mencken's 1919 Prejudices
17Back to top Go down    Re: Speedo cog on Tue Aug 09, 2016 10:21 am
Gary - pm me. I've just consigned a speedo to the bin as irreparable (broken needle spindle). I pulled the cogs off for you, FoC. Just as long as you don't need the tiny green one - the bastard flew across the bench somewhere and buried itself in a mixed bunch of Guzzi and BMW parts
18Back to top Go down    Re: Speedo cog on Tue Aug 09, 2016 10:37 am
If it is a MPH speedo the gears could be very different and with Dai being in the occupied territory then miles are still used.
19Back to top Go down    Re: Speedo cog on Tue Aug 09, 2016 12:49 pm
@RicK G wrote:If it is a MPH speedo the gears could be very different and with Dai being in the occupied territory then miles are still used.
There's got to be some comeback to that but I'm damned if I can think of it...
