1Back to top Go down    Loose mirrors on Wed Aug 17, 2016 11:12 pm
Rockman
My mirrors tend to creep downwards. Is there an easy way of tightening the ball joints?
2Back to top Go down    Re: Loose mirrors on Thu Aug 18, 2016 3:13 am
A few drops of lock tight ???
1987 K100 RS
1997 R1100R
1996 R1100GS
3Back to top Go down    Re: Loose mirrors on Thu Aug 18, 2016 3:28 am
Use the O-rings for garden hoses and put one over each thingy and that takes the wobble out. I cant remember the size but the hardware stores will have them in packets of 5 so you need 2 packets and then you have 4 to lose before you need any more.
Sorry Phil I missread your post. Make sure the ball it is dry and oil free then a small square of plastic bag (thickness depends on how loose it is) put it over the ball and press the mirror back on, it will last for a few years depending how often it is adjusted.
"Every normal man must be tempted, at times, to spit upon his hands, hoist the black flag, and begin slitting throats." from Mencken's 1919 Prejudices
4Back to top Go down    Re: Loose mirrors on Thu Aug 18, 2016 7:13 pm
Rockman
@RicK G wrote:Use the O-rings for garden hoses and put one over each thingy and that takes the wobble out. I cant remember the size but the hardware stores will have them in packets of 5 so you need 2 packets and then you have 4 to lose before you need any more.
Sounds the go, I'll try it over the weekend. They arent real loose, but normal road shocks will make them creep.
