1Back to top Go down   Horn problems...... KIS Empty Horn problems...... KIS on Tue Aug 23, 2016 11:04 pm
Yes, Keep It Simple!
My K100rt developed all the symptoms of having a bad angina or man flue (Yes Klompy...)
The 2 horns barely worked anymore.
First thing that I did was to open the left handlebar switch and generously sprayed a good squirt of Deoxit with no result. I then changed the horn relay with no more success. I was ready to remove the tank and start to check the ground and maybe overall the starter. However, the original test was giving me a full 12V at the horn connections.
I then plugged back the first horn and it was still barely vibrating. I unplugged it and plugged the second one and.... success! I got as loud Beeeeppp.
One bad horn was sucking all the power and the second one wouldn't work.
Horn problems...... KIS Frog15Horn problems...... KIS Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
2Back to top Go down   Horn problems...... KIS Empty Re: Horn problems...... KIS on Tue Aug 23, 2016 11:07 pm
FYI: You can find the exact same FIAMM horns brand new from auto parts retailers - without The Fatherland's markup.
