1Back to top Go down   Oil filter socket Empty Oil filter socket on Wed Sep 07, 2016 4:16 pm
Davep
Davep
Hi All,
 Just a quick one, 1983 K100rs, so therefore it has the hex end on the oil filter, as I was giving her a service I went to change the oil filter and found the socket still on the end of the old one! Is it me or should that not really have been left there? I have now popped it back into the tool box but it's playing on my mind!!
Oil filter socket Eu-log10BMW K100RS 1983 (Main ride)
                      Suzuki GSX 750 ET 1979 (Needs work)
                      Kawasaki Zephyr 750 1992 (Needs hiding)
2Back to top Go down   Oil filter socket Empty Re: Oil filter socket on Wed Sep 07, 2016 6:58 pm
Mate you are not the first to find this phenomenon and likely not the last...in fact one of ours here could not find his removal tool until checking much like you did.
great place to leave it as you cannot lose it there.....now where did I leave my glasses?
KKlompy
KKlompy Oil filter socket 2854237993
Oil filter socket Au-log10
3Back to top Go down   Oil filter socket Empty Re: Oil filter socket on Wed Sep 07, 2016 7:26 pm
BIG D
BIG D
Cool
As Klompy says, you have gained a filter tool  Very Happy
BIG D
4Back to top Go down   Oil filter socket Empty Re: Oil filter socket on Wed Sep 07, 2016 8:21 pm
Can I have my filter wrench back please?
(I wondered where that went.)
5Back to top Go down   Oil filter socket Empty Re: Oil filter socket on Wed Sep 07, 2016 9:55 pm
Davep, your original post sounds like you are under the impression that the oil filter type with the nut on the bottom is the standard filter for the K100RS.
This is not the case - a few brands such as K&N use the nut but most filters, including the original BMW ones, have the fluted section around the bottom for use with a cup tool for installation and removal. The K100RS uses the same filter as all other K75, K100, K1100 variants.
Plenty of threads on here re filters.
6Back to top Go down   Oil filter socket Empty Re: Oil filter socket on Thu Sep 08, 2016 12:39 am
Gaz is spot on re filters as there are heaps of different ones in shapes and sizes also. Many of us have found that the Ryco Z418 is a good fit and costs a heap less than imported filters. Just had a read back and yep 418's are an appropriate fitment...wow the engineering rigour that went into that question was amazing....good luck mate.
KKlompy
7Back to top Go down   Oil filter socket Empty Re: Oil filter socket on Thu Sep 08, 2016 4:06 am
R1100 and R1150 also
'87 K100RS/HRD sidecar (1100 motor)  sc25
'92 K100RS-16v (Paint it Black)
Oil filter socket K-dogs10
8Back to top Go down   Oil filter socket Empty Re: Oil filter socket on Thu Sep 08, 2016 4:31 am
@Davep wrote:and found the socket still on the end of the old one! Is it me or should that not really have been left there? I have now popped it back into the tool box but it's playing on my mind!!
I'm amazed that the filter cover went back on with a socket stuck to the bottom of the filter.
1988 K100RT     VIN No.  0094680
 Oil filter socket Austra12    Fuel:  95 Octane
9Back to top Go down   Oil filter socket Empty Re: Oil filter socket on Thu Sep 08, 2016 4:49 am
It will with the OEM filter but many of the replacement filters are a bit longer.
