1Back to top Go down   Instruments Empty Instruments on Mon Sep 19, 2016 3:59 am
nino
Hello, my km (mileage) counter stoped working both total an daily. Speedo works as usual. Where to look?
2Back to top Go down   Instruments Empty Re: Instruments on Mon Sep 19, 2016 4:13 am
the gears nino
there are many post about this ...usually its the 3rd and 4th cogs
but the little drive gear sometimes split as well
good luck
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%OInstruments Au-log10
3Back to top Go down   Instruments Empty Re: Instruments on Mon Sep 19, 2016 4:22 am
nino
Thanks Charlie, is it complicated repair?
4Back to top Go down   Instruments Empty Re: Instruments on Mon Sep 19, 2016 4:35 am
no not hard at all nino ...but getting the right gears is the issue
I'm sure living in Europe should be easier than out here down under
Instruments 2014-010
5Back to top Go down   Instruments Empty Re: Instruments on Mon Sep 19, 2016 6:55 am
nino
Charlie, is it possible just to change gears as complete unit because I have one spare speedo. I am horrified about possibility to change gear by gear?
As matter of fact I have mileage gears not kilometers.
6Back to top Go down   Instruments Empty Re: Instruments on Mon Sep 19, 2016 7:28 am
not sure nino ....to my way of thinking there is a slight difference in the odo ..versus the speedo ...the speedo has been graduated with different locations for the mph than the kph ...but the gears may have a teeth difference  to make it all accurate
sorry I don't have more experience with the mph odo gears ...
there are many posts in the forum if you use the search thingy
7Back to top Go down   Instruments Empty Re: Instruments on Mon Sep 19, 2016 12:58 pm
nino
Broken first double gear just like on your photo. Mine is orange (for kmh) and when I compared to the set in mileage which I have in garage I found that mileage gear was smaller in diameter.
Anybody know the source for plastic gears for km/h
