1Back to top Go down    Rear Brake Pedal on Tue Sep 27, 2016 8:45 am
JGT
The rear brake pedal on my K75 isn't obviously damaged but the square foot pad has a definite anti clockwise twist to it so my foot catches the outer edge and bottom right hand corner of the pad on applying the brake. I'm tempted to remove, apply some heat and try and bend it back so the pad is square to the bike. What type of aluminium is it? will it respond to this? if it has been bent and damaged will the Ali. have work hardened? John
1987 K75s 1969 Bultaco Matador
2Back to top Go down    Re: Rear Brake Pedal on Tue Sep 27, 2016 9:44 am
If you bend it back it will probably fracture. If you heat it and cool it quickly it will go soft and then can be straightened however it will then bend easily with the force applied in braking. If you can determine where the bend is then you can bend it back in a different place but they are still a bit prone to fracture. Best outcome is to get a good straight one without any salty corrosion (makes the under side look flaky).
"Every normal man must be tempted, at times, to spit upon his hands, hoist the black flag, and begin slitting throats." from Mencken's 1919 Prejudices
3Back to top Go down    Re: Rear Brake Pedal on Tue Sep 27, 2016 5:42 pm
Have a good read of this thread by Moto Smith onForging aluminium. I used this technique to straighten the rear pedal on my LT about 14,000 miles ago.
88....May contain nuts!
4Back to top Go down    Re: Rear Brake Pedal on Tue Sep 27, 2016 6:30 pm
BobT
If you have access to a potter oven or similar. Heat the part to 500c for 30 minutes, quench in water after removel from the oven and bend it how you want within about an hour. After that time it will start to slowly harden again.
5Back to top Go down    Re: Rear Brake Pedal on Tue Sep 27, 2016 6:44 pm
91 K75S
6Back to top Go down    Re: Rear Brake Pedal on Tue Sep 27, 2016 7:20 pm
"Just replace it with a good used one."
+1
K100RT 1987 (now nekkid with red bits)
Remember Rule No. 6
7Back to top Go down    Re: Rear Brake Pedal on Wed Sep 28, 2016 5:07 am
JGT
Confused I am! Went on Ebay to look for a replacement and they all seem to exhibit the same trait, the pad is not square to the pivot axis???????
8Back to top Go down    Re: Rear Brake Pedal on Wed Sep 28, 2016 8:16 am
None of them have a straight line from the base to the tip - otherwise they would be pointing outward a bit.
However, one that is bent slightly inward compared to how it came from the factory so that it is not parallel to the bike's direction can be annoying. (I had one before like that.)
91 K75S
9Back to top Go down    Re: Rear Brake Pedal on Wed Sep 28, 2016 8:24 am
Alternatively... a little dressing with a file, dremel or (very carefully) with an angle grinder, might be sufficient just to reshape the pad so that it doesn't catch on your boot ... but not so much that you substantially reduce the size of the pad. Just a thought.
Paul
"Gretel" K100LT 1989 (Silver Grey) (VIN 0177324 Engine No. 104EA 2789 2211) - 4th+ owner. September 2015 (58,500miles and counting....). Cat C Insurancewrite-off rebuild Feb 17
"Donor" K100LT 1990 (Red) (VIN 0178091 Engine No. 4489 2024) - 6th & final owner (crash write-off now donor bike). June 2012 (73,000 miles) to November 2013 (89,500 miles)
