1Back to top Go down   K100Rs 16v fork brace cover Empty K100Rs 16v fork brace cover on Thu Sep 29, 2016 12:49 pm
Curley
Curley
Hi all,
I am in need of a fork brace cover for my trusty steed as it must have flow off during a bumpy ride!
Does anyone have one laying around and willing to part with it?
K100Rs 16v fork brace cover Ir-log11K100Rs 16v fork brace cover Ir-log11K100Rs 16v fork brace cover Ir-log11K100Rs 16v fork brace cover Ir-log11K100Rs 16v fork brace cover Ir-log11
cheers  White K100RS 1991  cheers Red K1100LT SE 1995 cheers Green K75RT 1995 cheers
2Back to top Go down   K100Rs 16v fork brace cover Empty Re: K100Rs 16v fork brace cover on Thu Sep 29, 2016 6:23 pm
STEVE1959
I have one Curley, if you don't mind paying the postage from Australia
3Back to top Go down   K100Rs 16v fork brace cover Empty Re: K100Rs 16v fork brace cover on Thu Sep 29, 2016 6:33 pm
BobT
BobT
I'll look in the garage and see if I have one. If I do then I'll give it to Will (88) when he gets here in a couple of weeks time and he can bring it back for you.
4Back to top Go down   K100Rs 16v fork brace cover Empty Re: K100Rs 16v fork brace cover on Fri Sep 30, 2016 9:24 am
Curley
Curley
@STEVE1959 wrote:I have one Curley, if you don't mind paying the postage from Australia
Thanks Steve for the offer. If i cant find one then i might get you to post it to Rockhampton as i will be heading over at the end of Nov.
5Back to top Go down   K100Rs 16v fork brace cover Empty Re: K100Rs 16v fork brace cover on Fri Sep 30, 2016 9:25 am
Curley
Curley
@BobT wrote:I'll look in the garage and see if I have one. If I do then I'll give it to Will (88) when he gets here in a couple of weeks time and he can bring it back for you.
Really appreciate it Bob, you must have a treasure trove over there!
6Back to top Go down   K100Rs 16v fork brace cover Empty Re: K100Rs 16v fork brace cover on Fri Sep 30, 2016 11:31 am
BobT
BobT
Just found it but it is cracked. You are welcome to have it should you want to fix it and you don't have one. Just say the word and I'll give it to Will to bring back to you.
K100Rs 16v fork brace cover Dscn0610
7Back to top Go down   K100Rs 16v fork brace cover Empty Re: K100Rs 16v fork brace cover on Fri Sep 30, 2016 6:37 pm
STEVE1959
The one I have is a bit different to the one in the photo, it has a raised up section in the middle. It is from a 1993 K1100LT. If you still want it no problem to post to Rockhampton.
8Back to top Go down   K100Rs 16v fork brace cover Empty Re: K100Rs 16v fork brace cover on Mon Oct 03, 2016 5:33 am
Curley
Curley
@BobT wrote:Just found it but it is cracked. You are welcome to have it should you want to fix it and you don't have one. Just say the word and I'll give it to Will to bring back to you.
Thanks Bob. Not sure if its fixable though..
9Back to top Go down   K100Rs 16v fork brace cover Empty Re: K100Rs 16v fork brace cover on Mon Oct 03, 2016 5:34 am
Curley
Curley
@STEVE1959 wrote:The one I have is a bit different to the one in the photo, it has a raised up section in the middle. It is from a 1993 K1100LT. If you still want it no problem to post to Rockhampton.
Thanks Steve, i dont think it will fit as its slightly different to the one for RS.
Thanks a million.
