1Back to top Go down    Removing new road surface stuff from tyres on Mon Oct 17, 2016 11:47 am
Reg
Long and short of it, took the K11 out for a little blast last week, However the road home ( Galway to Cliften road) was been re-surfaced. Got to the stop/go traffic light system ( ie one side of road was blocked) and the Guy told me to race on and catch up with the traffic. So I did untill I came across a tractor with trailer, going VVV slow. So and the K11 does I nip passed only to see to workers waving their hands at me, so I pulled over. They pointed down the road, thats were I saw the lovely Line I took...... Then looked at me tyres to see the Road stuck to them Sad
Is there an easy way to remove tar and feathers from the tyres, or is it a scaple job...
Reg
Knowing what those guys use over there that stuff is hot bitumen. When it cools its lethal. Solvent of some sort will work, as in white spirit or petrol or normal car paint tar remover. That's how I get it off the car. You should get most of it off but treat the tyres as if they were new.
Other less preferred option is scrub it off as in ride it off but very very carefully. Wet and cold are something that don't go well with it.
1992 K100LT 0193214 Alaska Blue 101,000 miles
1984 K100RT 0022575 Baja Red bought 36,000 now 89,150 miles
1997 K1100LT 0188024 Mystic Red 58,645 now 67,600 miles
@Reg wrote:Is there an easy way to remove tar and feathers from the tyres, or is it a scaple job...
No, no, no. Don't remove it. Find a good dirt track and enjoy the fact that you've got your own personal bit of blacktop to ride on
Twisted Evil
Kando
Lucky you didn't have an 'off' .It's never happened that bad to me, but I remember somewhere reading that once it had set, the amount of solvent required to 'dissolve' it increased a lot, and larger pieces of it could be removed by getting the tyre really cold so that the tar becomes brittle and crumbles when tapped with a small hammer.
 I must say that I've never tried this and I for one wound not risk stuffing a tar covered tyre in The Management's frozen food, I would get an awful lot more than 'a cold shoulder' !
 Auto Glym sell a tar removing product that I have used but only on small blobs from the lower fairings, the amount need for a tyre might cost more than a new tyre perhaps?
@Dai wrote:No, no, no. Don't remove it. Find a good dirt track and enjoy the fact that you've got your own personal bit of blacktop to ride on
Twisted Evil
What would I do?
I probably wouldn't use any solvent type stuff on the tyre unless I tried it out on an old tyre first. Use it and check for oily, greasy, slippery residue?
You may have to spring for a new tyre?!?
K100RT 1987 (now nekkid with red bits)
Remember Rule No. 6
@blaKey wrote:What would I do?
Blakey
You are right with that, I had it happen before and white spirit shifts it. Much easier when its soft and hot. Problem is the residue and when you get it off you have to scrub the tyre in again. Cold wet weather here just now and the combination is fairly scarey. Not sure I would be happy on the twisties around Reg's way
David Nimrod
Agree on both counts!
I certainly wouldn't be using any solvents (or similar) on a tyre.
Just buy a new set of boots, and forget it
What I'm out for is a good time
All the rest is Propaganda!
Reg....buy a pound of ordinary butter and massage it into a section...it dissolves tar! Seriously!  Depending on how thick the tar is depends on whether the butter or a new tyre will cost more.
I ran onto some fresh stuff years ago with a jeep. The bodywork was badly spattered. Stuff from the auto factors was partially effective and after a suggestion from a mate I tried the butter which  was 100% effective with less rubbing...it took only 2 1/2 lbs to clean the body work...I would have used 3 but the dog ate it !!! Laughing
88....May contain nuts!
BobT
Cloth soaked in acetone.
@88 wrote:Reg....buy a pound of ordinary butter and massage it into a section...it dissolves tar! Seriously!  Depending on how thick the tar is depends on whether the butter or a new tyre will cost more.
Make sure its Kerrygold.
And yes it does work. Less elbow grease. But heed the dog warning. The buggers will be chasing after you like mad.
Chocolate
Hey!
Shit happens :-)
I wouldn't use any cleaner, instead I would freeze the wheels or wait for could/freeze weather. You will see how the stuff breaks of with a little help.
Doesn't get that cold here. It just p!sses down all year round.
Try kerosene or diesel. Apply liberally and brush. Think about where you do it because the run-off will soak into concrete, destroy grass and melt you bitumen roadway. I think anyway you do it, its going to be a tedious process. I've not heard of any adverse effect on tyres.
many years ago I worked in a bitumen hotmix plant as a lab tech. We used to wash samples for analysis with carbon tetrachloride and we used kero to clean bitumen off stuff including our hands. We also made a bagged product called 'Cold Mix' which was sold thru hardware store for DIYers to repair holes in their driveways etc. This was the same as 'Hot Mix' but diesel was added to keep the bitumenn wet till the bag was opened and applied to the ground where the diesel evaporated and the mix then set.
I've also heard that acetone will dissolve tar/bitumen but its going to be pretty expensive.
1988 K100RT     VIN No.  0094680
     Fuel:  95 Octane
Reg
Thanks for the feed back, I am currently gutting my shed to make room. and will let ye know how it goes. Not going to post any pictures, still dont trust the site after the nasty virus I got last time:)
