1Back to top Go down   Switchgear and Seat Lock Needed Australia Empty Switchgear and Seat Lock Needed Australia on Tue Oct 18, 2016 1:20 am
cliverocky
cliverocky
1985 K100RS
Need Right hand Switchgear or a starter switch fix
Seat lock
In Rochampton, Queensland
Still looking.
Have rang BMshop 3 times no answer so not keen to use
If no luck from any of us, try The BM Shop in Bris Vegas.
3Back to top Go down   Switchgear and Seat Lock Needed Australia Empty Still looking on Wed Feb 22, 2017 5:31 pm
cliverocky
cliverocky
Finally got onto BM Shop they are looking and will ring back.
Why is they no solution for this out there if it is such a problem
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%OSwitchgear and Seat Lock Needed Australia Au-log10
If you are expecting that mug from the BM Shop to ring back don't hold your breath he is well noted for not getting back
I have a RH switch assembly but as for a seat lock the only one is from a complete set of locks which I will not split.
PM if you are interested.
6Back to top Go down   Switchgear and Seat Lock Needed Australia Empty Got one on Wed Feb 22, 2017 9:34 pm
cliverocky
cliverocky
Just bought one from the BMW K-Model Shop in the above link.
But thanks anyway Rick
7Back to top Go down   Switchgear and Seat Lock Needed Australia Empty Great Service on Tue Feb 28, 2017 7:53 pm
cliverocky
cliverocky
I would like to thank BMW K-Series Motorcycle Spare parts for the great service in supplying the Switch
http://kmodelbeamerbits.com.au/bmwk-seriesshop.html
good to hear clive
you did notice that the connector may be different ... for those stuck in a bind a little cut and snip followed by heatshink and soldering might solve the issue
good luck mate
BobT
BobT
I gave a new seat lock to Olaf not so long ago, You can change the barrel to fit any key.
@BobT wrote:I gave a new seat lock to Olaf not so long ago, You can change the barrel to fit any key.
Puddings in exchange for seat lock will be delivered by Kourier in September.
Fuel tank barrel is same, you can get the barrel out to adjust it.
1997 K1100LT 0188024 Wotan Mystic Red 689 58,645 now 100,380 miles
1983 K100RS 0011171 Fricka 606 29,495 miles Damn K Pox Its a Bat outta Hell No 33,600 miles
