1Back to top Go down   16V cam chain tension release tool Empty 16V cam chain tension release tool Thu Oct 20, 2016 5:43 am
KiwiK100
KiwiK100
I am about to remove the cam chain cover on my '91 16V for inspection and don't have the "special" BMW tool to release the tension in the chain tensioner. Are there other options? I have searched here and cannot find any info on alternatives.
Can wise and experienced ones advise best procedures for this task.
Current rides:
2020 R1250RS. Metallic black with all the fruit
1983 K100C. Red. Krauzer fairing.
1984 K100RS. Madison silver.
2002 K1200RS. Owned from new. Pacific Blue, Ohlins, Speiglers, Fiamms, HID. 186,000km SOLD Crying or Very sad
1991 K1. Schwartz metallic black, 18 month frame off restoration. 74,000km SOLD Crying or Very sad
1987 K100RS Style. Black, Ohlins, Race Tech springs, Braided lines. Fully restored. 53,000 miles. SOLD Crying or Very sad
The family history:
1951 AJS 500 single - my Dads ride
1953 Triumph Terrier - my Mum's ride
1916 Triumph Type H, Battle of the Somme, France WW1 - my Grandads ride
3Back to top Go down   16V cam chain tension release tool Empty Re: 16V cam chain tension release tool Thu Oct 20, 2016 11:07 pm
You could just cable tie it so it won't expand any further and unbolt it. Once you've figured out how the mechanism works you can reset it and bolt it back in. Take a good look at it as it comes apart. Warning... springy bits inside..... scratch oh sh!t. Where'd that go! Laughing
Why do you need to release the chain tension? What are you inspecting? Chain/guides or are you replacing valve shims. You don't need to release the chain tension to check valve clearances.
 16V cam chain tension release tool Austra12    Fuel:  95 Octane
KiwiK100
KiwiK100
I wish to remove the cam chain cover and hall sensor cover to restore and paint as part of a K1 restoration. My 8V motor is straight forward and the K12 is also simple but the 16V is more complicated. 'corse I could just pull the cover off and pick up the pieces afterwards...
BTW PM sent re K1 tank bag
Current rides:
The family history:
Hmm....should have read more closely...did see camshaft chain and special tool...
and was thinking locking tool.
But what makes it so more difficult to remove the cover on a 16V compared to a 8V?
Kiwi... You can remove the cover no probs but crank and valve covers will need to come off first as well as the timing gear. This thread has info about that. There's no gasket available anymore for the timing chain cover so just use some Permatex. I use the Black one.
Probably a very good opportunity to replace timing chain and guides if you think they might need doing. It really won't take long if you have it down to that state anyway.
I have the bag here for you.
EDIT: After you remove the timing plate and then the rotor off the end of the crankshaft you will be able to remove the timing chain cover. Be careful how you do that as there is a seal located in the cover itself which seals over the end of the crankshaft.
