1Back to top Go down   new boy first post Empty new boy first post on Wed Oct 26, 2016 2:47 pm
grunter
grunter
I think with the bits I have I'm going down the café racer route
to try and keep the cost down (sorry in advance to the purists)
any money saving tips on replacement fuel injectors?
Grunt
england
2Back to top Go down   new boy first post Empty Re: new boy first post on Wed Oct 26, 2016 11:18 pm
@grunter wrote:any money saving tips on replacement fuel injectors?
Grunt
england
Clean them.  There are lots of videos on youtube showing how it's done.
3Back to top Go down   new boy first post Empty Re: new boy first post on Thu Oct 27, 2016 12:38 am
They can't be rebuilt, but they can be refurbished with new "o" rings, filter and pintle cap (eBay is your friend).
Someone from the Ol' Dart will chime in with what's available over there as a replacement.
4Back to top Go down   new boy first post Empty Re: new boy first post on Thu Oct 27, 2016 5:10 am
welcome Mate .
1987 K100RT  Ex- police
1989 K100LT  Ol' Blue and "Kart" the Kamper trailer.  now KAPUT .
new boy first post 10_x_110
5Back to top Go down   new boy first post Empty Re: new boy first post on Thu Oct 27, 2016 10:09 am
@grunter wrote:
..... any money saving tips on replacement fuel injectors?
Here's a tip that will save you quite a few dollars.... don't bother. As suggested by others above, just give them a clean and new kit. If you pull them out, make sure you clean out the recesses very well before hand to prevent crud falling into the intake manifold.
WelKome to the forum Grunt
  new boy first post Austra12    Fuel:  95 Octane
6Back to top Go down   new boy first post Empty Re: new boy first post on Thu Oct 27, 2016 11:00 am
Brad-Man
Brad-Man
WelKome!
new boy first post Usa-lo10
7Back to top Go down   new boy first post Empty Re: new boy first post on Thu Oct 27, 2016 12:18 pm
brickrider2
brickrider2
Welcome from across the Atlantic!
8Back to top Go down   new boy first post Empty Re: new boy first post on Thu Oct 27, 2016 12:31 pm
Welcome to the forum
Injector service kits are available from here.
http://mrinjectoruk.co.uk/default.aspx
You will need
kit 27
Bosch 0280150 series 4 cylinder early 2000 & before 15mm seal set No27
Very reasonable priced and easy to do.
new boy first post Ir-log10
   ;BMW; K100RS Style Black 1987 105K Km     ;BMW; K1 Black 1993 51K Km     ;BMW; K1100RS Red 1993 70k miles  ;BMW; K100 16V Black (ex ElectricMonk)  ;BMW;  K1100LT (Swiss) soon to be an RS
9Back to top Go down   new boy first post Empty Re: new boy first post on Thu Oct 27, 2016 1:17 pm
Chocolate
Chocolate
Cheaper repair set
http://www.aliexpress.com/item/32643718201/32643718201.html
Clean them with a ultrasonic from Aldi for 12€
How to DIY - How to install an injector rebuild service kit
10Back to top Go down   new boy first post Empty Re: new boy first post on Thu Oct 27, 2016 8:13 pm
Welcome, Grunt!
What  model and year is your bike? How long have you owned it? How many miles on it. How many have you put on it?
Anyway, I think you should consider trying this method then getting back to us, if possible.
Last edited by Laitch on Thu Oct 27, 2016 8:16 pm; edited 1 time in total (Reason for editing : Link correction)
1995 K75 73,000 miles
11Back to top Go down   new boy first post Empty Re: new boy first post on Fri Oct 28, 2016 1:46 am
Care is needed when selecting these kits. They aren't all the same. This kit Choco, is for a Bosch EV1 4 hole injector eg. #415. They have slightly different nozzle parameters than for the standard pintle valve injector eg. #210. The insulating cap which goes over the nozzle is slightly different size and design. Also I think the micro filter basket is slightly different.
This is the correct kit for the K100 #210 injector with pintle valve .
When cleaning, I pull the old micro-filter and cap off and give the injector a reverse flush.
Also, be careful applying constant 12V. Use a 9V battery just to be safe
12Back to top Go down   new boy first post Empty Re: new boy first post on Fri Oct 28, 2016 2:30 am
walfish
walfish
Oh Good, I have one of these, what liquid is safe to use other than water.
new boy first post 22936
new boy first post Uk-log10 88 K 100  0033026
                            92 K 1100 LT  6455097
13Back to top Go down   new boy first post Empty Re: new boy first post on Fri Oct 28, 2016 3:31 am
Chocolate
Chocolate
new boy first post Muc-Off-Disc-Brake-Cleaner-400ml-Aerosol-Bike-Cleaner-913-0
Thanks # Holister
You are right, I forgot that I already use the four hole injector.
You are right for the original injector.
HolisterThis is the correct kit for the K100 #210 injector with pintle valve .
14Back to top Go down   new boy first post Empty Re: new boy first post on Fri Oct 28, 2016 5:33 am
@Ringfad wrote:Welcome to the forum
You will need
kit 27
I like this one and for us its relatively 'local'. Got me thinking, on one hand if it's working leave alone but on other hand worth doing for the money. I can see a little workshop weekend somewhere there's an ultrasonic cleaner.......
1997 K1100LT 0188024 Wotan Mystic Red 689 58,645 now 100,380 miles
1983 K100RS 0011171 Fricka 606 29,495 miles Damn K Pox Its a Bat outta Hell No 33,600 miles
15Back to top Go down   new boy first post Empty Re: new boy first post on Tue Nov 01, 2016 2:34 pm
92KK 84WW Olaf.... wrote: .....I can see a little workshop weekend somewhere there's an ultrasonic cleaner.......
Not a bad idea.
Welcome to the forum. I've considered the cafe option for my k75 but in the end I've other machines that need attention more, what type of rear end are you going for? (It's the bit then makes or breaks the look of a cafe in my humble opinion)
new boy first post Ir-log11 88....May contain nuts!new boy first post Ir-log11
16Back to top Go down   new boy first post Empty Re: new boy first post on Tue Nov 01, 2016 5:25 pm
@grunter wrote:I think with the bits I have I'm going down the café racer route
Welcome Grunt...
No need to apologise...unless you are taking a decent bike and are breaking her down into a cafe racer...by the sounds of it "with the bits I have"  I guess you have something less than a complete bike to start with, so perhaps an ideal project bike.
Lots of advice and knowledge hereabouts, and much to be learnt from the ardent cafe job members as well as us more mortal purist!!
Enjoy and remember to share your pics, trials and tribulations.
new boy first post Uk-log10 new boy first post Sco-lo15new boy first post Eu-log10
                              Paul  new boy first post 905546712
