1Back to top Go down   Fuel level sender - tank O-ring Empty Fuel level sender - tank O-ring on Thu 27 Oct 2016 - 12:03
Been hunting all over but cant find the size and the only one I have to measure is umm well used.
The question is does anyone out there in Kland know the size of this O-ring.
Real OEM tells the size of just about every other O-ring but lists this as a gasket ring and doesnt give the size. Rolling Eyes
2Back to top Go down   Fuel level sender - tank O-ring Empty Re: Fuel level sender - tank O-ring on Thu 27 Oct 2016 - 12:17
I have one if you want it.
3Back to top Go down   Fuel level sender - tank O-ring Empty Re: Fuel level sender - tank O-ring on Thu 27 Oct 2016 - 13:02
Can you measure the outside and inside diameter please. That will give me the info I need.
I will be going to Toowoomba next Wednesday to get a nose job and can get some then.
4Back to top Go down   Fuel level sender - tank O-ring Empty Re: Fuel level sender - tank O-ring on Thu 27 Oct 2016 - 13:33
No problem...when I get home this arvo, I'll get the measurements.
Nose job? I thought it was big enough already! Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy Evil or Very Mad
5Back to top Go down   Fuel level sender - tank O-ring Empty Re: Fuel level sender - tank O-ring on Thu 27 Oct 2016 - 15:03
S'not good.
6Back to top Go down   Fuel level sender - tank O-ring Empty Re: Fuel level sender - tank O-ring on Thu 27 Oct 2016 - 15:41
Ever notice that your feet smell and your nose runs?
7Back to top Go down   Fuel level sender - tank O-ring Empty Re: Fuel level sender - tank O-ring on Thu 27 Oct 2016 - 19:58
Outer diameter 55mm:
Fuel level sender - tank O-ring Seal_110
Inner diameter 45mm:
Fuel level sender - tank O-ring Seal_310
Fickness 5mm:
Fuel level sender - tank O-ring Seal_210
8Back to top Go down   Fuel level sender - tank O-ring Empty Re: Fuel level sender - tank O-ring on Thu 27 Oct 2016 - 20:04
Thanks mate that should be easy to get. Fuel level sender - tank O-ring 112350
9Back to top Go down   Fuel level sender - tank O-ring Empty Re: Fuel level sender - tank O-ring on Thu 27 Oct 2016 - 20:25
@blaKey wrote:Ever notice that your feet smell and your nose runs?
Oh dear.... Fuel level sender - tank O-ring 652573
10Back to top Go down   Fuel level sender - tank O-ring Empty O-rings on Tue 14 Mar 2017 - 21:28
GF Wollongong
GF Wollongong
I ran into this problem some time ago (1 needed for 1984 K100 ... front LHS).
Long story short... bought a red box of o-rings for $17 ... can't find link right now
http://www.ebay.com.au/itm/10-Pcs-Black-Nitrile-Rubber-O-Rings-NBR-Seal-Grommets-55mm-x-5-7mm-/391240160723?hash=item5b17bb15d3:g:I9kAAOSw~AVYuS4Y
Have managed to use 2 so far. But it was still cheaper than getting played by BMW dealers
Hope this helps
G
11Back to top Go down   Fuel level sender - tank O-ring Empty Re: Fuel level sender - tank O-ring on Tue 14 Mar 2017 - 22:54
@GF Wollongong wrote:I ran into this problem some time ago (1 needed for 1984 K100 ... front LHS).
Hope this helps
G
JC,BWDALHSSF?
12Back to top Go down   Fuel level sender - tank O-ring Empty Re: Fuel level sender - tank O-ring on Thu 16 Mar 2017 - 15:43
GF Wollongong
GF Wollongong
http://www.ebay.com.au/itm/419-pc-PCS-METRIC-RUBBER-O-RING-ORING-ASSORTMENT-Auto-industrial-KIT-/191858489397
Attached is the link to the box of o-rings - oil and petrol proof. Just an assorted box of o-rings from an automotive supplier - should be pretty common
Though not sure if it is the size Rick was after
There is this bigger box but the biggest size tops out at 50mm inner diameter
http://www.ebay.com.au/itm/826-PCS-RUBBER-O-RING-ASSORTMENT-KIT-419-METRIC-407-IMPERIAL-/181278987255
Hope this is of use to others
Regards
Guy
13Back to top Go down   Fuel level sender - tank O-ring Empty Re: Fuel level sender - tank O-ring on Thu 16 Mar 2017 - 18:11
I just took my old one into CBC Bearings and bought half a dozen for about $1 each. You can get them easy enough from Motorworks for about £2 each also. Freight can be a killer so I'd only order from them when ordering other stuff.
1988 K100RT     VIN No.  0094680
 Fuel level sender - tank O-ring Austra12    Fuel:  95 Octane
14Back to top Go down   Fuel level sender - tank O-ring Empty Re: Fuel level sender - tank O-ring on Mon 3 Apr 2017 - 0:35
Beemer Wheeler
Beemer Wheeler
I had to replace it 2 years ago, luckily a mechanic enthusiast across the road had a box of rings, and sold me one for 2 EUR.
Pain in the neck to replace in freezing winter weather, but that was a cheap fix.
Good thing I checked gas level before going on a run, as my half thankful was showing empty but there was some gas left, not much, & a strong gas odour.
I did not see a puddle as the brick stood on gravel/dirt.
1986 K 100 RT "K-T" short for "Katie" 117.000 Km
   Fuel level sender - tank O-ring 2cr0y2r  Fuel level sender - tank O-ring 116p8ic
2012 Yamaha YFL 381 (Flute)
2005 Yamaha PSR E-203 (Keyboard Synth).
2012 Yamaha 7 HP outboard engine
"Beemer Wheeler" Certified Brick Aviator since July 2013
Ham radio call sign ON7BAS
http://h2fuel.mobi
