Number of posts : 11685
hi tom,
just thought to post a pic of my noisy bevel box
I should have done it before .
the main bearing once cleaned of oil is quite noisy .when taking just the weight of the output shaft , and you can see the scoring on the bearing surface of the other end
I'm just pulling it apart for inspection before the Karuah run as the seal on the output (the big one ) is still weeping
I'm going to re-linish the running surface and shove it all back together and relocate the seal , till I can afford replacement bearings, as there is likely a tiny bit of movement
reminder this bevel box sat for really long time before I got it , and suspect that there may have been some corrosion - pitting on the bearing race faces
