1 Apparent shifting failure -- anything I should look for? Sat Nov 26, 2016 10:23 pm
FreyZI
Hello,all. Following up on my new member post from a few days ago. Thanks for the welKome.
A couple weeks ago I bought a 1985 K100RT in disrepair and not running. The bike had been ridden just over 100K miles (I would guess well cared for) and then gifted about two years ago to a guy who did not take care of it. He quickly wrecked it with his buddy on the pillion, damaging the fairings and mirrors, and busting the rear brake master cylinder. He let it sit for a long while on a gravel driveway, where it was knocked over and broke the shifter lever at the neck next to the foot shaft. As you can imagine, there are a few things (fuel pump, filter, etc.) that need replaced.
I have disassembled the bike so I can get the frame powder coated and do all necessary clean up. I've also removed the final drive, swing arm, and transmission to do spline lubes. Happily, all of the splines look to be in very good condition.
Here's the question: Before disassembly, as now with the transmission on the workbench, I am not able to run through the gears. From what I assume to be neutral, I can shift down and hear an audible click I assume to be first gear. I can shift up (again into neutral) with an audible click. However, I'm not able to shift into second or further up. No audible click, can't feel any engagement. The shifter level will raise and go so far, but nothing by way of indication that it has shifted.
I'm reasonably mechanically inclined and I have no trepidation about braking into the transmission, although I have never messed around with one before. Anything you'd be on the lookout for with the symptoms I've described?
Many thanks!
Frey
Many thanks!
Frey
