Number of posts : 7867
The BT45 on the front was an interesting one but am very happy with it.
I had Lasertecs on both Ks and found them terrible in our climate.
The BT45s were a great improvement. I now change front and rear together. The front needs to be kept up to 38psi to reduce or avoid scalloping but it does inevitably happen. Keeping the pressure up I now figure forces the tyre to run on and wear the centre harder compound when the bike is upright, rather than sitting down a little and wearing the softer side compound. I get about 12,000 miles on the rear [which I keep at minimum 42psi] and the front is more than excellent up to that mileage. I am happy with that and to replace both tyres together. I did keep fronts a bit longer but after the rear was changed the scalloping on the front increased to the point where I didn't like the front. My current set was put on at end of October and I expect they will be replaced before the summer
Dai rides all year here in the same climate, so does 88, BAE, Sidecar Paul and a few more and our climate is much the same as UK. I think they use different tyres but at least its the same riding conditions.
What has amazed me is the difference in a bad tyre seems not so noticeable if you are riding about 10-12C but its very noticeable under 5C. I suspect about 15-20C any tyre is probably good especially harder ones.
1971 Yamaha 125 YAS-1
