1Back to top Go down    Odyssey battery PC680 on Mon Dec 12, 2016 6:35 pm
jolo994
jolo994
Hello BMW K100ers...I am working on a 1984 K100RT that im planning to turn into a 'Brat Bike'...Can i use the Odyssey PC680 mounted sideways?
Im planning on relocating the battery and all the relays/fuses and mounted thinly under the seat...if the PC680 doesn't work sideways which battery will?...thx Jolo
2Back to top Go down    Re: Odyssey battery PC680 on Mon Dec 12, 2016 6:58 pm
BobT
BobT
Yes you can use them any way up. You can also get away with one smaller than a PC680, a PC535 would do. The 535 has 200 CCA which is more the the small Yuasa that I have fitted (180CCA).
3Back to top Go down    Re: Odyssey battery PC680 on Mon Dec 12, 2016 7:15 pm
@jolo994 wrote:Can i use the Odyssey PC680 mounted sideways?
This is the Odyssey Technical Manual.
This is a quote from that manual:
Installing the ODYSSEY battery in any orientation other than inverted does not affect any performance attribute. There is also no fear of acid spillage.
Inverted means upside down.
1995 K75T 68,000 miles
4Back to top Go down    Re: Odyssey battery PC680 on Mon Dec 12, 2016 8:33 pm
jolo994
jolo994
Thank You, Im going with the PC680 since its thinner...thank you both...Happy Holidays!
