1Back to top Go down   Instruments compatibility? Empty Instruments compatibility? on Tue Dec 27, 2016 9:00 am
nino
Hello and happy holidays to all. Anybody knows about instruments compatibility. May i use k 1100 instruments in K 100 1986?
2Back to top Go down   Instruments compatibility? Empty Re: Instruments compatibility? on Tue Dec 27, 2016 10:01 am
Chocolate
Chocolate
Hello!
Technical all K instruments work.
But!!!
On the backside of the instrument cluster the pins are different.
Either round from until 1988/1990 ore square from 1990 -
The fuel indicator is different, they are different in the tank and on the instrument!
So the K1100 ore 8 valve instrument will not fit because it has round pins and you will nett square pins!!!
K100 1100 8 valves
Instruments compatibility? S-l300
K100 K75 With or without ABS
Instruments compatibility? $_1
Old fuel indication K100 until 1986 without ABS
Instruments compatibility? Mtmpic
Round pins on the backside of the instrument
Instruments compatibility? Img_2611
Left side square pins, right side round pins at the Wiring harness
Instruments compatibility? Img_2610
3Back to top Go down   Instruments compatibility? Empty Re: Instruments compatibility? on Tue Dec 27, 2016 10:37 am
nino
Thanks for quick answer. I have first generation of fuel level sender in tank but I adjusted second generation instruments (1986) to fit by changing PCB in instruments. I have a red reserve light on 7 liters left.
Round pins could be the only problem. Do you know any good workshop for instruments in Germany, or source for first generation instruments?
4Back to top Go down   Instruments compatibility? Empty Re: Instruments compatibility? on Fri Dec 30, 2016 4:45 am
@nino wrote:Thanks for quick answer. I have first generation of fuel level sender in tank but I adjusted second generation instruments (1986) to fit by changing PCB in instruments. I have a red reserve light on 7 liters left.
Hi mate do not be concerned as round and square do fit together....I have a K100RS 1984 with 1990 instruments....I have also fitted many others of all years...Tacho and speedo and odometer will work but fuel indication requires some playing around with internals.
good luck...I always refuel at 250 km ...easy peasy
KKlompy Instruments compatibility? 2854237993
Instruments compatibility? Au-log10
5Back to top Go down   Instruments compatibility? Empty Re: Instruments compatibility? on Fri Dec 30, 2016 4:52 am
Motorbike Mike
Motorbike Mike
With some very basic alterations, swapping the tank would be easy too if you're wanting a fuel gauge.
6Back to top Go down   Instruments compatibility? Empty Re: Instruments compatibility? on Fri Dec 30, 2016 3:49 pm
nino
Thanks. I have one more question: What instruments are more reliable, later 1100 model or earlier 100?
I had a lot of problems with older one
7Back to top Go down   Instruments compatibility? Empty Re: Instruments compatibility? on Sat Dec 31, 2016 10:13 am
Neither are more reliable than the other because they are all of the same basic design and construction.  If you've had problems with the earlier models it's because of the life they may have lead (i.e. more corrosion on connectors) or because the electronic components are reaching the theoretical MTBF.
