1Back to top Go down   Gauge angle adjustment?  Empty Gauge angle adjustment? on Tue Feb 14, 2017 11:13 pm
Koa
Koa
I searched but I may have overlooked the correct info. I have a 1985 k100 RT (kinda). I swapped the fairing and handlebars and all the stuff that goes along with that.
Here's where my question begins. Is there a different mount for the gauge cluster? Can the tilt be adjusted? The RT seems to be more upright than the RS. I been looking at photos to see if it is just my imagination but I don't think it is.
2Back to top Go down   Gauge angle adjustment?  Empty Re: Gauge angle adjustment? on Tue Feb 14, 2017 11:27 pm
Yes, the RT and the RS have different mounts for the gauges. They are not adjustable. But they can be swapped.
'87 K100RS/HRD sidecar (1100 motor)sc25
'92 K100RS-16v (Paint it Black)
Gauge angle adjustment?  K-dogs10
3Back to top Go down   Gauge angle adjustment?  Empty Re: Gauge angle adjustment? on Wed Feb 15, 2017 1:01 am
Here's my experience.
I bought another set of clocks for my 84 K100RT. The ones I got came off an 84 K100RS. The new ones came with the mount but when I went to fit them it with the new mount which was in much better condition than my one butwas a no go. So I took off the mount and compared them side by side, they were not identical but both had the same BMW part no cast into them. The RS mount had 2 tabs at the rear of the mounting bracket which I had to cut off to make it identical to the RT mount so it wouldfit the RT. But the angle seemed to be the exact same.
1997 K1100LT 0188024 Wotan Mystic Red 58,645 now91,850 miles
1983 K100RS 0011175 Fricka 29,495 miles Damn K Pox
4Back to top Go down   Gauge angle adjustment?  Empty Re: Gauge angle adjustment? on Wed Feb 15, 2017 7:29 pm
Koa
Koa
Thanks for the feedback guys. I'll keep my eyes out for another mounting bracket. Or perhaps I'll add some wedge shaped washers.
Olaf, is it possible that the tabs tipped the mount further back?
5Back to top Go down   Gauge angle adjustment?  Empty Re: Gauge angle adjustment? on Thu Feb 16, 2017 2:26 am
It might have been that because when I tried the new ones with the mount on I couldn't get them into position, but what puzzled me was both mounts had the same part number cast into them.
6Back to top Go down   Gauge angle adjustment?  Empty Re: Gauge angle adjustment? on Thu Feb 16, 2017 3:29 am
What a few here have done is to put an aluminium extrusion 15mm x 8mm from the 2 holes on the top clamp where the gauges bolt to the 2 corresponding holes on the bottom clamp and mount the gauges on those bars. That way you can choose the angle and height as they do stick up a fair way when there is no fairing.
"Every normal man must be tempted, at times, to spit upon his hands, hoist the black flag, and begin slitting throats." from Mencken's 1919 Prejudices
7Back to top Go down   Gauge angle adjustment?  Empty Re: Gauge angle adjustment? on Thu Feb 16, 2017 3:48 am
Make your own mounts from scratch to suit you - that's what I did with both of my bricks because I wanted the panel lowered. I used 3mm steel. You should be able to use the original mount to work out the offset to the instrument panel mounting holes.
[Edit] 2mm steel will probably do - 3mm was what I had handy.
8Back to top Go down   Gauge angle adjustment?  Empty Re: Gauge angle adjustment? on Thu Feb 16, 2017 7:32 pm
I've done a custom headlight mount on both of my K bikes and used two different mount brackets for the instruments (because that was what I could find at the time of each project), I then fabricated a custom piece to attach the particular bracket to the forks at the height/angle that I wanted. I have posted photos below, one off an RS and one off an RT. This approach may save a little time in comparison to fabricating the whole bracket from scratch as Dai has done by the sound of it.
Gauge angle adjustment?  Yhst-110
Gauge angle adjustment?  Images10
On my K1100LT the OEM instrument mounting was integral with the main front fairing bracket.
Good luck.
1990 K75 6427509; 1987 R80G/S PD 6292136; 2010 G650GS ZW13381;95 K1100LT 0232224
9Back to top Go down   Gauge angle adjustment?  Empty Re: Gauge angle adjustment? on Fri Feb 17, 2017 4:25 am
